Silvaco Atlas Syntax question - area from curve
The discussion centers on a block of Silvaco Atlas code used for extracting data related to electron concentration in a semiconductor simulation. The user seeks clarification on how the parameters like x.val and integration ranges function, specifically questioning the integration over x values while setting a cutline in the y direction. Additionally, there are inquiries about integrating along a specific y range and the significance of the impurity parameter in the context of electron concentration. The user also expresses confusion regarding where to find the integration results, as the output file "extract.dat" contains depth information rather than the expected integrated value. Overall, the thread emphasizes the need for a clearer understanding of the syntax and functionality of the code.
GaNHEMT
I have a several questions on the following block of codes taken from ganfetex01_aux.in:
Code:
solve
save outf="ganfetex01_$'index'.str"
extract init inf="ganfetex01_$'index'.str"
extract name="2DEG" 1e-4 * area from curve (depth, impurity="Electron Conc" material="All" mat.occno=1 x.val=0.5) \
                         where x.min=0 and x.max=0.5 outfile="extract.dat"
My understanding is that this code saves the solution in a file named "ganfetex01_$'index'.str", then the first EXTRACT statement create its own data to work with from the saved file. The second EXTRACT statement integrates the electron concentration from x=0 to x=0.5, and save this value in a variable named "2DEG".
Questions:
1. My understanding is that x.val sets the cutline, and the integration is over (x.min=0, x.max=0.5). Is that correct? I am confused since x.val would set the cutline along the y direction, but the integration is over the ranges of x. Shouldn't the integration be over the range of y values? Where is this exactly integrating?
2. What should I do if I want to integrate over (y=0, y=0.5) along the cutline x=0.5?
3. what is the purpose of impurity in "impurity="Electron Conc"? I get that it is integrating the electron concentration, but why impurity=?
4. Where can I check the integration result "2DEG"? I thought this would be saved in "extract.dat", but "extract.dat" file saves electron concentration vs. Depth information. For example, Electron Conc vs Depth 0 4e-7 0.0025 4e3 0.005 2e19 . . .
Try the Silvaco site.
click on the search icon at right end of the red banner
enter: user manual
if you get a drop-down with just a few results, click the last line of the dropdown, that should get you a list of over 200 search results
Have Fun!
Tom
Likes GaNHEMT and berkeman
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
