Simple analog voice distortion circuit
  • Thread starter Thread starter fede.na
    Analog Circuit
A user is attempting to build a simple analog voice distortion circuit without using integrated circuits (ICs), focusing on components like a microphone, speaker, oscillators, analog multipliers, and RLC filters for real-time distortion. The goal is to achieve a robotic sound, but any interesting distortion is acceptable. Suggestions include using ring modulation and generating pseudorandom mixer carriers for enhanced effects. After some experimentation, the user encountered issues with audio separation when using a PC's stereo output, noting that mixing tracks improved the sound quality. The discussion highlights challenges in circuit design and troubleshooting audio signal processing.
fede.na
Hi, I'm trying to build a simple analog voice distortion circuit, without any ICs if it's possible. It can get pretty hard to hunt down a specific IC around here.
Anyhow, my idea was to get a mic, a speaker, a few oscillators, analog multipliers and RLC filters to build a real time distortion (it will be a portable device, so it will be DC powered). I know it's probably too much to ask, but the original idea was that the distortion came out as kinda robotic, but it's not a must, any cool distortion will do it.
Can anyone point me in the right direction? I'm sort of the electrical engineering student with a lot of theoretical knowledge and little experience, so spare no explanations. Maybe just tell me a good waveform to multiply the input with and i'll search how to do it.. any help is appreciated. Pretty much everything I found involved an IC, so if I there's any chance I could avoid that, that'd be great.
Thanks!
Wow that was fast and very helpful, thank you very much nsaspook! I'll post how this turns out in case anyone is interested.
I hope you make something cool. With the proper circuits to generate pseudorandom mixer carriers you can even make a pretty good voice scrambler device that sounds similar to this:
ParkHill
Voice Inversion:
Simple inversion scrambler
Hi again! So I built the modulator and it works great... but there's something weird about it. I'm using my PC's stereo output to feed both the audio signal and the 30Hz carrier wave. The audio on the left channel and the 30Hz wave on the right channel.
I'm generating the signals in Audacity, but here's the weird thing: when I do a 100% separation of the tracks between channels, I can't hear almost anything. When I let a little bit of the carrier onto the other channel, it sounds a lot like it should... like youtube videos demonstrating the circuit. If I just go 50% both signals, i.e. not splitting the tracks at all between the channels, as if it were mono output I guess, it sounds perfect...
Why does this happen? It's really weird. I tried to contact the guy who made that tutorial but didn't find any contact info.
Thanks in advance
As a wild guess, maybe you have the center tapped windings connected incorrectly.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
