Simple average question using sig figs within ± 0.0 of uncertainty?
The discussion revolves around calculating the average mileage from a set of measurements while considering significant figures and the specified uncertainty of ± 0.0 mph. The average mileage was initially calculated as 26.60833333, but confusion arose regarding the interpretation of "within ± 0.0 mph." It was clarified that this means the answer should be presented with one decimal place, effectively rounding to 26.6 mph. The final consensus is that the correct average mileage, adhering to the significant figures rule and the specified uncertainty, is 26.6 ± 0.0 mph. This highlights the importance of understanding how to apply significant figures in calculations involving uncertainty.
bobi
Simple average question using sig figs within ± 0.0 ?
Consider the following measurements of mileages:
23.8 mph, 20.1 mph, 26.5 mph, 20.7 mph, 21.7 mph, 27.6 mph,
30 mph, 28 mph, 27.4 mph, 34.3 mph, 26.5 mph, 32.7 mph.
What is the average mileage (using sig figs)?
Answer in units of mph Your answer must be within ± 0.0 mph.
Avg=Total Sum/number of variables
The average calculated was 26.60833333. And Since two variables have only two sig figs, I thought the answer should be 27. But it was a wrong answer.
But the last part of question asked the answer to be within ± 0.0 mph.
What does 'within ± 0.0 mph' means? No uncertainty? Or typo of 0.1 or 0.01?
What should be the correct answer?
Welcome to PF, bobi! :smile:
'within ± 0.0 mph' means within ± 0.05 mph.
That is, with 1 digit after the decimal point.
So your average would be 26.6 ± 0.0 mph
Thanks a lot!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
