High School Simple forces described in terms of fundamental forces
When two objects approach each other, they cannot touch due to the repulsion between electrons and the Pauli exclusion principle, both of which prevent matter from collapsing into a denser state. The Pauli exclusion principle stops particles from occupying the same space, while electron repulsion keeps solid objects from passing through one another. These principles, along with the attractive and repulsive forces between electrons and nuclei, help maintain the shape and structure of solid objects. The discussion also raises the question of whether forces like friction, normal, air resistance, and spring are fundamentally related to these concepts. Understanding these interactions is crucial for grasping the nature of physical forces and how they operate in our environment.
SamRoss
TL;DR
How can non-fundamental forces such as friction and tension be described in terms of fundamental forces?
My first question is actually, what happens when any two objects get near each other? This question is often phrased as "Why can't you really touch anything?" or "Why can't you walk through walls?" I have heard two answers: 1. the repulsion between electrons 2. the Pauli exclusion principle. Which of these is correct or are they both right?
Once that's settled, how can each of the following forces be described?
Friction
Normal
Air resistance
Applied
Spring
Muscular
Tension
Is it fair to say that the first five (friction through spring) are really just the same as my first question - that is, due to electron repulsion or the Pauli exclusion principle? How would tension and muscular forces be described on a fundamental level?
Likes Delta2
The PEP keeps matter from potentially collapsing into a super-dense state except under enormous pressure, while the repulsion between electrons keeps one solid object from passing through another. Both concepts, along with the attractive/repulsive forces between electrons and/or nuclei, are responsible for the ability of a solid object to maintain its shape and structure.
Likes vanhees71 and Delta2
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 35 ·
  • · Replies 16 ·
