Simple gamma matrices question
Ameno
Hi
I've just read the statement that a matrix that commutes with all four gamma matrices / Dirac matrices has to be a multiple of the identity. I don't see that; can anyone tell me why this is true?
Thanks in advance
You can deduce this yourself using the completeness properties of gamma matrices. By considering (schematically) 1, \gamma, \gamma \gamma, etc. one can form a basis of matrices.
If you can decide:
1) that this basis is complete for 4x4 matrices
2) that nothing in this basis besides 1 commutes with all the \gamma
then you will have what you want.
Thanks.
OK, I also had this answer in mind (which I already found), but I thought that there is a simpler answer because this statement appeared at a point in the script where that basis has not yet been introduced. Perhaps I'll find a simpler answer, but I'm also fine with this one. At least I see that it's not that simple.
Yeah, I wouldn't necessarily claim this is the most elegant method. One could even explicitly compute the commutator of an arbitary 4x4 matrix with the four gamma matrices. This gives 4 4x4 linear matrix equations that will give the same conclusion. This is even less elegant but requires no mention of a basis.
Yes, but wouldn't this require a choice of representation? It would not require a choice of basis, but it wouldn't be canonical in the sense of independence of representation.
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
