Simple harmonic motion (finding omega)
A particle in simple harmonic motion with an amplitude of 2.51 cm is analyzed to find the displacement where its speed is half of the maximum speed. The maximum speed is represented as vmax = Aw, and the relationship between speed and displacement is established using energy equations. It is clarified that the angular frequency (w) and spring constant (k) are not necessary to solve the problem, as the displacement can be determined directly from the velocity condition. The discussion emphasizes that understanding the relationships in the equations allows for solving the problem without all constants. The key takeaway is that the displacement can be found using the derived relationships without needing to calculate w or k.
SteroidalPsyc
A particle executes simple harmonic motion with an amplitude of 2.51cm. At what positive displacement from the midpoint of its motion does its speed equal one half of its max speed?
A=2.51 cm
x(t) = Acos(wt)
v(t) = -Awsin(wt)
vmax = |-Aw|
I just want to know how to find w so I can plug it into the vmax equation.
A=2.51 cm
x(t) = Acos(wt)
v(t) = -Awsin(wt)
vmax = |-Aw|
You actually don't need to plug it in. If v_{max} = Aw then \frac{v_{max}}{2} = \frac{Aw}{2}
Just use the energy equation
\frac{1}{2}kA^2 - \frac{1}{2}kx^2 = \frac{1}{2}mv^2
where v= \frac{Aw}{2}, and remember to sub \frac{k}{m} for w^2.
I don't know what k is though. How do I find k?
Divide both sides by k!
O ok haha sorry I'm really tired. Thanks for the help I solved it!
You don't need the velocity or the angular frequency in order to answer the question. You're only asked at what displacement the velocity has half its maximum value.
x=A\cos{(\omega t)}
v=-\omega A \sin{(\omega t)}
v=-\omega A \sqrt{(1-\cos ^2 {(\omega t))}}
v = -\omega \sqrt{(A^2-x^2)}
|v|=\tfrac{1}{2} v_{max}=\tfrac{1}{2}\omega A
\tfrac{1}{2}\omega A = \omega \sqrt{(A^2-x^2)}
You don't always need all the constants involved in a problem in order to solve for a particular value. :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
