Simple harmonic motion spring problem
The discussion revolves around a physics problem involving two masses attached to springs on a frictionless surface, with the goal of determining the time it takes for the particles to align at x = 0 m after being released. The participants calculate the angular frequencies for both masses using the spring constant and their respective masses, finding w1 = 2.0 rad/s for m1 and w2 = 2.1 rad/s for m2. They note that the frequencies and periods of the systems are independent of amplitude, allowing them to express the positions of the masses as sinusoidal functions. The key insight is that the particle with the lower frequency will move slower, leading to a point where both particles meet at zero. The discussion concludes with a plan to visualize the problem further to ensure accuracy in calculations.
Dylan.Wallett
The drawing shows a top view of a frictionless horizontal surface, where there are two springs with particles of mass*m1*and*m2*attached to them. Each spring has a spring constant of*120*N/m. The particles are pulled to the right and then released from the positions shown in the drawing. How much time passes before the particles are side by side for the first time at*x*= 0 m if the following masses are used: m1 = 3.0 kg m2 = 2.7 kg
w = squ root k/m - frequency of vibration
w = 2 pi/T
E=1/2mv^2 + 1/2kx^2
I am pretty stumped with this one. I feel we need to know the distance that the two particles were pulled to and then released.
I started with
m1 - w= squ root k/m
= squ root 120/3.0
= 2.0 rad/s
m2 - w= squ root k/m
= squ root 120/2.7
= 2.1 rad/s
Thanks
I can't find your drawing. Are you sure that it was properly attached?
Sorry - not sure what happened. I have attached it again. Hope it comes through this time
Much better.
The frequencies and periods of the two spring-mass systems are independent of their amplitudes, depending only upon the masses and spring constants. If you let ω1 and ω2 be their angular frequencies respectively, then you should be able to write an equation for the position of each with respect to time as sinusoidal functions. Since you're only concerned about where these functions are zero, you can just set their amplitudes to unity.
I see now that the one particle will be going slower than the other and therefore if released together at the same time the amplitudes will be in unity and will create two sinusoidal functions that will meet at zero.
So I will make w1 and w2 = f1 and f2. Find the periods (which should be equal) and then find out the time at X=0. I am going to draw it out and try and find out if there are mistakes I have written here.
Thanks for putting me on the right track.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
