Simple integrals for gravitational potential
In summary, the conversation is about solving integrals using substitution, specifically \int \frac{dx}{(a+x)^2}. The solution involves substituting u = x+a and using the formula \int {(u)^{-2}}{du} = -\frac{1}{u} along with a constant c.
MikeGomez
344
I need help solving intergral…
[tex]\int \frac{dx}{(a+x)^2}[/tex]
I found the integral for…
[tex] \int \frac{dx}{(a^2+x^2)} [/tex] = 1/a arctan x/a
But I don’t know how to apply that to the original integral which is a little different
[tex]\int \frac{dx}{(a+x)^2} = \int \frac{dx}{(a^2+x^2+2ax)}[/tex]
I also need to solve the following integral
[tex]\int \frac{dx}{(a+b-x)^2}[/tex]
It’s not homework. The reason is that I want to work through the numbers that Rybczyk gives as equation 1 for gravitational potential in his paper “Gravitational Effect on Light Propagation”
http://www.mrelativity.net/Gravitat...ravitational Effects on Light Propagation.htm
I have simplified his equation in my post somewhat, as I already know how to separate the two terms separated by the minus sign, and assuming the gravitational constant G and the mass of the bodies are constant, I know that they can come out in front of the integral sign.
Also, I changed the variable names to more familiar ones. I hope the variable name substitutions helps rather than hinders. If not I'll have to rewrite this whole post using Rybczyk's exact variables..
Thanks.
Thanks.
For the initial integral, use substitution, letting u = x+a .
Thanks Sammy. It looks to me like du = dx in this case. Is that right?
[tex]\int \frac{dx}{(a+x)^2} =[/tex]
[tex]\int {(a+x)^{-2}}{dx}[/tex]
u = a + x
du = dx
[tex]\int {(u)^{-2}}{du}=[/tex]
[tex] -\frac{1}{u} + c[/tex]
[edit] made correction (forgot the + c)
Substituting a + x for u gives
[tex] -\frac{1}{a+x} + c[/tex]
Is that right?
u = a + x
du = dx
[tex] -\frac{1}{u}[/tex]
[tex] -\frac{1}{a+x}[/tex]
Is that right?
Yes, it's right.
Great, thanks Dick (quick reply!).
Will try same for the second part of original question.
NOTE: I editied post #3 to make a correction for the missing ( + c) for a constant.
FAQ: Simple integrals for gravitational potential
What is gravitational potential?
Gravitational potential is a measure of the gravitational potential energy per unit mass at a specific point in a gravitational field. It is a scalar quantity, meaning it has only magnitude and no direction.
How is gravitational potential calculated?
The gravitational potential at a point is calculated by dividing the gravitational potential energy by the mass of the object. The formula for gravitational potential is V = -GM/r, where G is the gravitational constant, M is the mass of the object creating the gravitational field, and r is the distance from the object to the point where the potential is being measured.
What is a simple integral for gravitational potential?
A simple integral for gravitational potential is an integral that can be easily solved using basic calculus techniques. In the case of gravitational potential, the integral is usually a single variable integral, with the variable being the distance from the object creating the gravitational field.
Why is calculating gravitational potential important?
Calculating gravitational potential is important in understanding the behavior of objects in a gravitational field. It allows us to predict the motion and interactions of celestial bodies, as well as understand the structure and evolution of the universe.
What is the difference between gravitational potential and gravitational potential energy?
Gravitational potential is a measure of the potential energy per unit mass at a specific point in a gravitational field, while gravitational potential energy is the total potential energy of an object in a gravitational field. Gravitational potential is a scalar quantity, while gravitational potential energy is a vector quantity, as it takes into account both magnitude and direction.
9K
