Simple no-pressure cosmic model gives meaning to Lambda
In summary, the size of the universe is accurately tracked by the function u(x), which scales distances down by the cosmological constant a(x). "Dark energy" (as Lambda is sometimes excitingly called) is here treated simply as a time scale. Multiplying an ordinary time by ##\sqrt{\Lambda/3}## is equivalent to dividing it by 17.3 billion years, so to take an example, suppose your figure for the present is year 13.79 billion, then the time x-number to use is: x_{now} = \sqrt{\Lambda/3}\ 13.79\ billion\ years=
  • #71
Jorrie said:
While the derivation of this approximation is interesting and educational, the result is more easily (and probably more accurately) obtained by Lightcone 7. To simulate a "no Lambda" flat universe, just copy and paste the max allowable [itex]R_\infty[/itex] (999999) into the box, set S_upper to 2 (or whatever). ...
Thanks. I'm glad you approve of the exercise. Interest and hands-on learning are the main aims, in fact. The simple model here (I think George Jones first suggested it to us, it may be well-known) seems to approximate Lightcone numbers fairly well as long as one stays away from the radiation dominated era ( e.g. don't go earlier than, say, year million). Basically AFAICS Lightcone is the online gold standard. I'm constantly checking number calculated with this simple "by hand" method to see how well they agree. I see the two things working together in the same learning experience.
I hadn't planned on including a "no Lambda" calculation. The "20" calculation was just a sample of a substantially smaller Lambda. But I see one could get the required distances as you describe---using a large Hubble radius.
Space news on Phys.org
  • #72
marcus said:
I shall use the notation ρ* and put in frequent reminders that the cosmological constant term is here on the left side, so there is no Lambda contribution to the energy density.
I'm comfortable with this as a valid interpretation of the standard model, assuming that Lambda is really constant. If proved otherwise, then "simple, no-pressure" may have to be abandoned, but that's surely not for beginners. I think this is a very useful introductory approach...
  • #73
A related pedagogical paper: "A new standard model of the universe" by Gron,
http://arxiv.org/abs/0801.0552
  • #74
Øyvind Grøn of Oslo University. Neat! :oldbiggrin: I see he has some of the same-shaped curves! coth for H(t) and sinh2/3 for the scale of a sample distance growing over time. Crucial differences--I wouldn't want to mix discussion of the two models--but interesting. Thanks GJ, I'm glad to know of Grøn's paper
  • #75
I'm exploring ways to present the flat LambdaCDM as it works any time after the early years when radiation was the dominant content. As soon as matter takes over from radiation as the main component of their combined energy density ρ* , the standard cosmic model equations simplify and there is a reasonable facsimile of LambdaCDM that we can work by hand.
Here we use the same two basic inputs used in the Lightcone calculator: present and future Hubble times 14.4 and 17.3 billion years, and the same independent variable S = z+1=1/a, the wave and distance stretch factor. It is the reciprocal of the normalized scale factor, so S=1 denotes the present and its definition extends into the future.
I assume that the two Hubble growth rates Hnow and H have been determined to be 1/14.4 and 1/17.3 per billion years.
The essential point here is that if we make 17.3 billion years and 17.3 billion light years our units of time and distance then the Friedmann equation (the main cosmic model equation) takes a remarkably simple form.
First notice that the present Hubble growth rate is simply 17.3/14.4 = 1.2014 per unit time. If you call our new unit of time a "Uday" then the present rate is 1.2 per Uday, and the eventual Hubble growth rate is exactly one. H = 1 per Uday.
An important term that appears in the Friedmann equation involves the square growth rates:
Hnow2 - H2
And that turns out to be 1.443 - 1 = 0.443
To make a short story even shorter, when we use these units of time and distance the Friedmann equation basic to cosmology simplifies to:
H(s)2 - 1 = 0.443s3
I've described earlier in the thread how this is derived from the more recognizable form of Friedmann:
H2 - H2 = [const.] ρ*
I'll review that derivation later, and it's not hard so you may see for yourself how it goes. But now let's just look at the extremely simple version of the cosmic equation.
Something to notice is how close this equation is to observation---observation of actual wavelengths of light.
If you are visiting an observatory at night and the telescope is trained on a galaxy and you are told the stretch factor is 2, the wavelengths coming in are TWICE what they were when the light was emitted and headed our way,
then you can almost do in your HEAD the calculation of what the Hubble expansion rate was back then when the light was emitted. 2 cubed is 8.
And 8 times .443 is about 3.5.
Plus 1 is 4.5, whose square root is 2.1.
So you can remark to your astronomer friends: "I know what the Hubble growth rate was back then when the light was emitted! It was a little over twice the longterm rate."
If you wanted to spell it out in terms of years instead of the longterm rate unit, it is 2.1 times the longterm rate of 1/17.3 per billion years, so 2.1/17.3, or about 1/8.1, per billion years.
So you could add: "The Hubble time must have been around 8.1 billion years back then!"
Likes fuzzyfelt
  • #76
To take another example, suppose your friend is observing a galaxy and says the incoming light has stretch S = 3.
3 cubed is 27, times 0.443 is about twelve.
Add one and take the square root. The square root of 13 is about 3.6.
So the Hubble growth rate back then, when the light was emitted, was 3.6 times the longterm rate.
The longterm expansion rate H is our natural UNIT for picturing growth rates, and I am trying to think in terms of that. So I won't bother to work out what that would be in "per-billion-Earth-year" terms. But you could, if you want, divide 3.6 by 17.3.
To review a bit. We look at the standard cosmic model, ΛCDM, focusing on the spatial flat matter-dominated case. and we let an important feature of that model, namely Λ, determine our scale of time and distance. The square root of Λ/3 is the longterm growth rate H, in the standard model. And the corresponding Hubble time, 1/H is generally estimated to be around 17.3 billion years. We treat that as one "universe day", or Uday.
so the longterm growth rate H is now our unit growth rate. As it happens the current rate of distance growth Hnow is about 20 percent larger. It is 17.3/14.4 = 1.2014. That number and its square, 1.443, help to characterize the present for us.
In terms of our new time scale, Hnow = 1.201 per Uday and Hnow2 is 1.443 per Uday2
The Friedmann equation, the basic cosmic model equation, simplifies on our time-scale to:
$$H(s)^2 -1 = 0.443s^3$$
where s is the stretch factor, s = z+1. In the Lightcone calculator the stretch factor is capital S. I may have to switch over to that, or alternate s and S.
S = 2 denotes a time in the past when distances were 1/S = 1/2 their present size.
The wave stretch of light received today tells us the distance it has traveled---how far it is now from its source matter. This includes the effect of distance expansion while the light was in transit.
$$D(S) = \int_1^S \frac{ds}{\sqrt{0.443s^3 + 1}}$$
  • #77
$$H(s) -1 = 0.443s^3$$
You seem to have missed a squaring in the above: should be [itex]\small H(s)^2 -1 = 0.443s^3[/itex] (?)
  • #78
Corrected. Thanks for catching that.
  • #79
Not wanting to be pedantic, but why not just stick the constant 17.3 in front of the proper distance integral and let the answer come out in Gly, like we are used to on this forum? You are using the constant 0.443, which comes from it anyway...
  • #80
I know what you mean, Jorrie. Tried that earlier. This is exploratory. I want to see what the approach looks like when you go all the way over to the new units. Time scale 17.3 Gy and distance scale 17.3 Gly. If I was doing a practical calculation where I wanted to compare results with your calculator, I'd certainly stick a 17.3 out in front and save a step in the calculation as was done here.
marcus said:
And we evaluate these integrals which give the distances in billions of lightyears:
$$ D(S) = 17.3 \int_1^S T(s)ds = \int_1^S (0.443 s^3 +1)^{-1/2}ds$$
BTW if you have the time and want to help explore this and post some equations/derivations/explanations here in thread, it would be very welcome.
  • #81
In this scale of time and distance the Friedmann equation simplifies to $$H(s)^2 -1 = 0.443s^3$$
and a flash of light's distance from its source simplifies to $$D(S) = \int_1^S \frac{ds}{\sqrt{0.443s^3 + 1}}$$
I guess my observation about the number 0.443 is that it doesn't depend on Earth years or any particular human units. Rather it depends on this present moment in universe history. Imagine people on a different planet with a different year, perhaps not even using years to measure time but some "second" defined using their own atomic clock.
They could still measure [itex]H_{now}[/itex] and [itex]H_\infty[/itex]
and they would still find that
$$\frac{H_{now}}{H_\infty} = 1.201...$$ $$(\frac{H_{now}}{H_\infty})^2 = 1.443...$$
  • #82
I agree, but am still unsure about the wisdom of scaling the equations to the so-called "long term Hubble time (or radius)" 1/H. The conventional method is to scale to 1/H0, which is an LCDM-model-independent observable (AFAIK). I don't think 1/H is.
The penalty for doing so is (perhaps) a slightly messier equation, but then it correlates directly with what everyone reads in the textbooks.
Starting with your $$H(S)^2 - H_{\infty}^2 = (H_0^2 - H_{\infty}^2)S^3 $$ (which is 'cool') and normalizing for H0=1 instead of (your) H, we get $$H(S)^2 - \Omega_\Lambda = (1-\Omega_\Lambda)S^3$$ or $$H(S)^2 - \Omega_\Lambda = \Omega_m S^3$$
Any student will recognize this as the matter + cosmological constant 'first Friedmann' for the spatially flat LCDM model.
  • #83
Hi Jorrie, thanks for pointing out that alternative. I think they are both interesting ways to present the standard LambdaCDM cosmic model in a simple post-radiation-era spatial flat version.
I think you could argue that they each have advantages and it's somewhat a matter of taste. Maybe both should be developed in tandem and both should be available for teacher and student inspection.
It's clear that in our lifetimes the quantity 14.4 billion years is not going to change (except to be determined more precisely) so even if in principle it is an accident special to the present moment in time one can and does use it as a a time-scale! I think that's the essence of what you suggest here.
The current Hubble growth rate 1/14.4 per billion years is not in a strict sense a "constant" but it is practically speaking constant enough to provide a convenient timescale. So why not use it? At least it is less arbitrary than "years" the orbit period of this one particular planet in this one little solar system! :oldbiggrin: I can see the point. It also makes the equations nice. Probably we should explore both.
Also we don't KNOW that Einstein's curvature constant Lambda is actually a constant of nature's geometry. We are admittedly in the dark about that. I think what I am doing is testing something out. We don't know that the speed of light is constant, but so far evidence supports the idea. We don't know that Planck's hbar is a constant but so far it seems to be. And so far it looks like there's this curvature constant Lambda in nature. Let's suppose it really is a constant and tailor a bit of expository writing around that---treat it as such IOW.
  • #84
So, Jorrie, the premise here (at least within the confines of this thread) is that there is this growth rate H whose square is Λ/3, a third of Einstein's curvature constant. And that this growth rate H is a universal constant of nature which is not going to change "as long as the rivers run to the sea" (as the European colonists and the Native Americans used to write forever in their treaties) :smile:
I don't know if you take much interest QG threads in BtSM forum---you may or may not have noticed this development: Several approaches to formulating quantum geometry/gravity use simplexes to represent quanta of geometry (triangles, tetrahedra, pentachora).
It's been found interesting and possibly useful, instead of using flat ones, cut out of flat space, to use simplexes with a constant curvature Lambda. It's conceivable that nature's simplexes are actually not flat, but very slightly curved.
This is one motivation for wanting to try treating Lambda as a geometric constant of nature, which, as such, defines a natural time scale.
  • #85
I have no problem with Lambda as a constant - both approaches assume that. My concern is more that we may confuse students with this unconventional 'natural time scale', while the Hubble time is well known and documented. AFAIK, it is also the more directly observable one; the value of 1/H is still more uncertain.
'Pushing the boundaries' may not be appropriate for beginners courses, but more advanced students will certainly find this stimulating. So the 'tandem approach' that you mentioned may be a good option.
  • #86
Just have time to begin this post, company just arrived. Will edit these quotes from earlier posts down to essentials as soon as I have time
==revised excerpts==
I think the matter density estimate just comes from observing the lack of overall curvature and calculating the (matter+radiation only) CRITICAL. As far as concerns me, Lambda is not an energy and does not gravitate the way matter density does. It's just the original Einstein curvature constant. In the model discussed here, the Friedmann equation , for our purposes in this thread, has Lambda on the left hand side as reciprocal square time (the square of a a distance growth rate).
$$H^2 - \frac{\Lambda}{3} = \frac{8\pi G}{3c^2}\rho^*$$Friedmann equation inherits that Lambda, on the LHS, directly from 1917 Einstein GR equation.
*Reminder: as I just said, ρ* is a matter&radiation density. It does not contain any "dark energy" component. The curvature constant Λ is explicitly on the left side. This equation must be satisfied for there to be overall spatial flatness.
By definition
$$H_\infty^2 = \frac{\Lambda}{3}$$Therefore the Friedmann can be written this way:
$$H^2 - H_\infty^2 = \frac{8\pi G}{3c^2}\rho^*$$This shows that as the matter&radiation density thins out the growth rate H must approach a longterm limit growth rate H. I put an asterisk on the density as a reminder that, as the density of matter and radiation, it doesn't involve a Lambda component. The equation must be satisfied for spatial flatness and so, in that sense, once the current and longterm expansion rates H and H have been determined, ρ* is critical for spatial flatness.
A few posts back, Wabbit pointed out a useful version of the Friedmann equation (for matter-era on into indefinite future, since there is no "Lambda era") that saves a fair amount of bother, writing density, and constants like π and G etc. I'll write it using the wavestretch factor that Jorrie introduced in the Lightcone calculator. s=1 denotes the present.$$H(s)^2 - H_\infty^2 = (H(1)^2 - H_\infty^2)s^3$$The main novelty in this thread is the way in which Λ, or more precisely T = 1/H serves as a time scale. So to proceed we should evaluate the terms in the equation. Obviously the present value of the Hubble constant is 173/144 = 1.201... and its square is 1.443. Obviously, in the timescale we are using, H = 1 and its square is 1.
The RHS of the Friedmann equation evaluates to:
$$H(s)^2 - H_\infty^2 = (H(1)^2 - H_\infty^2)s^3 = 0.443s^3$$
And in our time scale the Friedmann simplifies to:
$$H(s)^2 - 1 = (H(1)^2 - 1)s^3 = 0.443s^3$$Since the Friedmann equation simplifies to $$H(s)^2 -1 = 0.443s^3$$a flash of light's distance wave stretch factor s = z+1 which we can read directly from it tells us how far it has gotten from its source, how far away its source now is:
$$D(S) = \int_1^S \frac{ds}{\sqrt{0.443s^3 + 1}}$$This can be used to DETERMINE H from standard candle distance redshift data as discussed earlier. So in that sense this is a universal form of the Friedmann equation at this point in the history of the cosmos.
My observation about the number 0.443 is that it doesn't depend on Earth years or any particular human units. Rather it depends on this present moment in universe history. Imagine people on a different planet with a different year, perhaps not even using their planet's years to measure time but some other natural cycle. They could still measure [itex]H_{now}[/itex] and [itex]H_\infty[/itex] and as long as they are our contemporaries they would still find that
$$\frac{H_{now}}{H_\infty} = 1.201...$$ $$(\frac{H_{now}}{H_\infty})^2 = 1.443...$$==end of revised quotes==
  • #87
The distance growth rate (Hubble parameter) as a function of time is given by an unusually simple equation. I'll use x to denote time in units of
1/H = T = 17.3 billion years. Exploring the use of that scale is basically what we are doing in this thread. On that scale the present epoch is 0.8 , more precisely 0.797 but 0.8 is close enough. It is just the usual age in billions of years, 13.8, divided by 17.3.
Nature seems to like that scale because in those terms the growth rate at any given time in history is simply the hyperbolic cotangent$$H(x) = \coth(\frac{3}{2} x) $$The scale factor, the size of a generic cosmological distance as it grows over time, is also give by a hyper-trig function, the hyperbolic sine$$u(x) = \sinh^\frac{2}{3}(\frac{3}{2} x) $$For some purposes it's nice to have the scale factor NORMALIZED to equal one at the present epoch. To normalize this we just find out its value at x = 0.8 and divide by that so that the new scale factor a(x) is forced to take the value 1.$$a(x) = u(x)/u(0.8) = u(x)/1.311$$
  • #88
There was an earlier curve that also belongs to this model and that I want to recall. It is the INVERSE of the normalized scale factor a(x) as a function of time x. Remember we are measuring time in "Universe days" or "Udays" of 17.3 billion years so the present is x=0.8.
What the normalized scale factor does , given a time x, is tell you the size of distances back at time x, compared with now. The formula is
$$a(x) = \sinh^\frac{2}{3}(\frac{3}{2}x)/1.311$$The 1.311 is just a normalization factor put into make sure that a(x) = 1 at the present epoch.
We might want to solve that in reverse. For instance some light comes in at the observatory and we put it through a grating to spread out the various colors/wavelengths and we recognize a hot sodium line but the wavelength is THREE TIMES that of the yellow light that hot sodium makes in the lab.
So while that light was traveling to us, wavelengths and distances were stretched three-fold. Distances were 1/3 their present size. So a(xthen)=1/3.
And we wonder WHEN WAS THAT? When was it when that galaxy emitted the light I just put through the grating? What were things like? What was the distance expansion rate back then? How far away is that galaxy now?
So we want to find the time x, for which a(x) = 1/3. Want the reverse or inverse function of the normalized scale factor a(x)
Call it x(a) if you like, the time x that corresponds to a scale factor a.
$$x = \frac{2}{3}\ln(\sqrt{(1.311a)^3} + \sqrt{(1.311a)^3+1})$$It's basically just the inverse of the hyperbolic sine, sinh. Here's the plot. It should look sort of like one half of that earlier ("antelope horns") a(x) picture turned over on its side:
Notice that it gives the right age of the universe. :smile: Light with scale factor a = 1 is emitted and received in the present, without any stretch. For a=1 the curve says the time x = 0.8. That is 0.8 Udays or 80% of our time unit 17.3 billion years---namely 13.8. Here's some earlier discussion which gives some other examples.
marcus said:
To recap, in this thread we are examining the standard LambdaCDM cosmic model with some scaling of the time variable that simplifies the formulas, and makes it easy to draw curves: curves showing how the expansion rate (percent per billion years) changes over time, how a sample distance grows over time, and so on.
Time is measured in units of 17.3 billion years. If it makes it easier to remember think of that as a day in the life of the universe: a Uday.
I've been using the variable x to denote time measured in Udays,
Our unnormalized scale factor u(x) = sinh2/3(1.5x) shows the way a generic distance grows.
Normalizing it to equal 1 at present involves dividing by u(xnow) = 1.311.
The normalized scale factor is denoted a(x) = u(x)/1.311.
The fractional distance growth rate H(x) = u'(x)/u(x) = a'(x)/a(x) = coth(1.5x)
Note that the normalized scale factor a is something we observe. When some light comes in and we see that characteristic wavelengths are twice as long as when they were emitted, we know the light began its journey when a = 0.5, when distances were half the size they are today.
So by the same token the unnormalized u = 1.311a is observed. We just have to measure a and multiply it by 1.311.
Knowing the wavelength enlargement we can immediately calculate the TIME x (measured in Udays) when that light was emitted and started on its way to us. Here is x as a function of the number u.
$$x = \frac{2}{3}\ln(\sqrt{u^3} + \sqrt{u^3+1})$$Since u = 1.311a, we can also write time as a function of the more readily observed number a.$$x = \frac{2}{3}\ln(\sqrt{(1.311a)^3} + \sqrt{(1.311a)^3+1})$$Here's a plot of the time x(a) when the light was emitted as a function of how much smaller the wavelength was at emission compared with the wavelength on arrival.
You can see, for example, that if the wavelength at emission was 0.2 of its present size, then that light was emitted at time x = 0.1. since time unit is 17.3 billion years, that means emitted in year 1.73 billion.
On the other hand if the wavelength was originally 0.8 of its present size, which mean it has only been enlarged by a factor of 1.25, then the light was emitted more recently: at time x = 0.6.
Multiplying by our 17.3 billion year time unit we learn it was emitted around year 10.4 billion.
You might think the curve is useless to the right of a = 1 (which denotes the present). But it shows the shape and, come to think of it, tells something about the future. If today we send a flash of light which later is picked up in a distant galaxy by which time its wavelengths are 40% larger---1.4 of their present size---what year will that be?
You can see from the curve that it will be time x=1.1
which means the year will be 17.3+1.73=19.03---about year 19 billion.
And the curve also tells how long the universe has been expanding, just evaluate the time at a=1.
  • #89
So just for fun (or for hands-on practice) let's do an example. I realize I didn't put in the curve for a(x) yet, I only put the curve for the Unnormalized scale factor u(x), where we didn't divide by 1.311 to make it equal one at the present day. So here is the normalized scale factor a(x). This is the most basic curve of the model. It shows how the size of the universe (or a sample distance) changes over time:
You can see how a(x) equals one at the present time (0.8 Uday).
I think of this as the "antelope horns" picture. : ^)
So imagine we are at an observatory and some light comes in that has been wave-stretched 5-fold. What does it tell us? It comes from a time when distances were 1/5 their present size, so 0.2 on the vertical scale.
When was that? We can see from the red curve that the time was x = 0.1, one TENTH of a Uday, one tenth of 17.3 billion years. But we are using the Uday time scale so we don't bother to convert to billions of Earth years, we just think of it as time x = 0.1
What was the expansion rate H(x) back then? We just put x=0.1 into our tanh formula (that gives the Hubble time, one over that gives the Hubble rate)
tanh(1.5*0.1)
Google says:
tanh(1.5 * 0.1) = 0.14888503362
IN OTHER WORDS GROWTH BACK THEN WAS ABOUT SEVEN TIMES THE LONGTERM GROWTH RATE
The eventual longterm growth rate is a good unit to think in terms of. We are used to it by now in many guises: one per 17.3 billion years, 1/173 percent per million years. 1/17.3 per billion years, about 0.06 per billion years. It is the eventual growth rate the universe is heading towards. and 1/0.1488 is about 7.
So when that light was emitted which we just analyzed, the growth rate was 7 times eventual.
If you want Hubble time in billions of Earth years, just multiply the 0.1488.. by 17.3 and you get 2.5757...billion years. I would read the Hubble growth rate from that as 1/26 of a percent per million years. It's somewhat a matter of taste and habit what you find the most comfortable way to express and think about the Hubble distance growth parameter.
  • #90
How far is that galaxy from us now? We were thinking of an example were some light came in with stretch factor 5, from a galaxy back in the time when distances were 1/5 what they are today. And we used our model to say WHEN that was (time x = 0.1, or year 1.73 billion)
and also used our model to say what the growth rate H(x) was, back then (about 7 times the universe's longterm rate).
So suppose now we ask how far that galaxy is now? How far has this flash of light traveled from its source? (on its own and aided by expansion).
This is a job for the "number empire" integrator. We integrate out to the incoming stretch factor s=5.
$$\int_1^5 \frac{ds}{\sqrt{.443s^3 + 1}}$$
You google "number empire definite" and you get
http://www.numberempire.com/definiteintegralcalculator.php
and you just type in the integrand and the limits 1 and 5. It's easy.
The integrand is (0.443*s^3+1)^(-1/2). You press "compute"
It gives 1.38, that is the distance to the galaxy in light Udays our distance unit when we use this time scale. So if you like, mulitiply the 1.38 by 17.3 billion light years to get it in those Earth year terms.
And we can tell right away what the distance to the galaxy was THEN, when the light was emitted and started on its way to us. Distances were 1/5 their present size back then so divide 1.38 by 5.
Basically the light you receive tells you all these things by showing you how much it was stretched.
  • #91
In terms of this model, how do we think of today's distance growth rate?
Well just as our time unit is the longterm Hubble time T = 1/H [ = 17.3 billion years]
our unit growth rate is H
So we measure the current growth rate by comparing it with the eventual rate that growth is tending towards.
And it turns out that current rate is 20% larger. Hnow = 1.20 H
or, with excess precision, 1.2013
That is where the number 0.443 in the distance integral came from, in the previous post.
1.20132 = 1.443
In our terms, the number 0.443 is Hnow2 - 1
today's date: 0.8
today's expansion rate: 1.2
In a sense what we're doing is describing the universe in its own terms, or in terms which, as far as we can tell, are eternal.
The current growth rate is always changing, declining actually, albeit slowly, so it seems awkward to use it as a unit of measurement. On the other hand, as far as we can tell the longterm growth rate is a constant. It is where the current rate is tending. So on that account it is better adapted for use as a unit.
So we measure the present growth rate in terms which have nothing to do with our planet's year, or human time-keeping conventions, but which take their meaning from the overall behavior of the universe.
Furthermore we state the present age in unchanging terms, which conceivably might be understood in the distant future and perhaps even cross culturally. This moment, the time since the start of expansion, we express in terms of a unit which we have reason to believe is universal
  • #92
Marcus, I have just posted my conclusion to the "new jacket" for your simplified model and I now fully concede that what you are doing here is far superior. I would suggest that you consider writing this up in a paper, because I think it is also superior to the published Grøn simplified model.
  • #93
Thanks so much for the encouragement, Jorrie! What we are doing in this thread is part of an informal unplanned PF collaboration involving you, George Jones, and Wabbit, as well as myself.
I can't think of any place better to post a brief summary of this simple cosmic model than your website (Relativity-4-Engineers) alongside the Lightcone cosmic histories calculator. I'm a big fan of Lightcone, as you know, and I think the two go together because you can check the results of the simplified formulas given in this thread against the tables and curves generated by standard LCDM cosmology embodied in Lightcone.
If you have the inclination and energy to post a description at R-4-E don't hesitate. I can't imagine that would preclude anybody from writing the model up later in some more publishable form. You are welcome to copy selectively and edit from any of my writings here if you want to patch something together for R-4-E.
My feeling is that examining and weighing alternatives (some of which you were doing in the other thread) is part of a rational development process and contributes to perspective, so I'm glad you were covering that angle.
  • #94
I'm coming into this late, but it seems to me that what you are saying is that the Friedmann equation without radiation has a simple enough form to allow three levels of simplification:
1) a trivial level that since the only unknown for a flat universe is the ratio of dark matter to dark energy, all relevant a[x] solutions form a one-parameter family of solutions based on that ratio, expressed via the Lambda parameter
2) a more interesting level that since the form of the mass density and dark energy density are simple monomials, the one-parameter family of a[x] solutions admits a rescaling of a and x, based on Lambda, such that the rescaled a[x] is a single universal function.
3) a particularly lucky level that the universal function can be written closed form.
That is pretty neat indeed-- nature has been kind to offer these simplifications, we would be foolish not to take advantage of them.
Then there is also the deeper question of whether or not there is physical significance to these simplifications, or whether it is just a happenstance mathematical convenience that nature has been so nice. After all, we did have to neglect radiation, though note a similar simplification is possible in early times, when there is no dark energy to worry about, and then the universal function also has a closed form, it looks like 1 - Sqrt[1+x]+x*Sqrt[1+x]/2 in some appropriately scaled way. So at early times, it looks like we have one appropriately scaled universal function, which transitions before recombination into your universal function, though the latter is scaled in a different way which depends on the ratio of dark matter to dark energy rather than the radiation-to-dark-matter ratio. Does the fact that we have these universal functions reveal some deeper physical insight?
It seems that you like to think of it as an insight in the sense that we can think of dark energy entirely in terms of how it scales that universal function to bring it into contact with our sense of distances and times. Also, we can think of the dark matter density in similar terms, entirely about the scaling of the early-time universal function to bring it into contact with our concept of space and time in that early period. Since we are restricting to flat universes, which is a reasonable thing to do, this is a potentially powerful way to think about those two parameters. Instead of thinking about dark matter as a mass density, we can think of it as a rescaling of the early-period universal function into space and time, and instead of thinking of dark energy as an energy density, we can think of it is a rescaling of the late-period universal function into space and time. These two rescaled universal functions merge into each other in a transition regime that can be approximated by a kink where they cross, though would be awkward to treat accurately. That does seem like a potent re-interpretation of cosmological dark matter and dark energy to me.
  • #95
Looks like I overlooked LambdaCDM in my Lame "Cantor Dust" post earlier today...a lot of good that c-minus in trig 50 years ago did me...
  • #96
This is a question for anyone who has been reading this thread and has ideas about it. Do you think portions of the material here would be suitable for introductory presentation in the new "PF Insights" context? What would you cover? How would you title it? What would you not include?
Should it be co-authored? It's the result of an accidental unplanned interaction involving George Jones, Jorrie, Wabbit, myself, and others.
Would anyone like to produce a draft or outline for how an "Insight's" piece could go? Comments on any of my writing here, and suggestions, are welcome. We can draft and edit here, if desired, and only submit it later, if it seems appropriate.
The basic idea is this (but this doesn't have to be stated explicitly, just understood). In several branches of physics it is normal to use units where natural recurrent quantities are set equal to 1. E.g. in cosmology often G=c=1, or 8πG=c=1. In other research you might see Planck's ħ = 1, or Boltzmann's constant k=1. It makes the equations simpler and can actually aid intuition. You are using units of measurement and scales that nature "likes".
So in cosmology we study the distance growth rate H(t) and how it changes over time, and how you can test that with observations. I'll restrict this to the spatially flat case (all the evidence supports overall near spatial flatness.) Overall spatial curvature might not be exactly zero but it is so close to zero that this flat model gives an excellent approximation.
And as far as we can tell the growth rate H(t) has behaved (and will behave) like this:
when you look at this what stares you in the face is a natural unit---of growth per unit time. The curve has a limit, call it H, which in Earth year terms (not the natural unit, but a familiar one) is about 0.06 per billion years.
If we make that our unit rate then its reciprocal becomes our unit of time and according to the most recent measurements that quantity 1/H of time which becomes our unit is in a narrow uncertainty range around 17.3 billion years. For convenience we can use a name for this unit of time. Unless there's strong objection or someone has a better idea let's call it one universe day, or Uday. Maybe we could just call it a Day, with a capital letter. For definiteness let's fix our unit time to be a Uday of 17.3 billion Earth years. Or is a Day that equals 17.3 billion years?
So that's the longterm distance growth rate. In the long-range future a distance will grow by a millionth of its size in a millionth of a Uday. (or should I say in a millionth of a Day?)
And what about the present rate of growth? Hnow has been measured quite a lot and is known to be around 1.20 H
More exactly Hnow = 1.201 (to avoid round-off error I might sometimes use 1.2014).
The main thing is that the square Hnow2 = 1.443
The square growth rate is what enters in the main cosmology equation, the Friedmann equation.
  • #97
In our terms the Friedmann equation (in the spatial flat case) takes this form:
$$H^2 - H_\infty^2 = [constant] ρ^*$$
Where ρ* is the combined energy density of radiation and matter (including both ordinary and dark matter)
The density now satisfies $$H_{now}^2 - H_\infty^2 = [constant] ρ_{now}^*$$ and based on observations we know that in our units the left hand side is 1.443 - 1 = 0.443
But matter density increases as the cube of the stretch factor s. If wavelengths and distances in some era are being stretched by a factor of 2 between then and now, then distances were 1/2 their present size back then and matter density was 8 times its present value. Except in the very early universe matter is the main component and we neglect radiation in the next equation.
So $$ρ^* = ρ_{now}^*s^3$$ The density at any other time is just the density now multiplied by the cube of the s-factor corresponding to that time. $$H(s)^2 - H_\infty^2 = [constant] ρ_{now}^*s^3 = (H_{now}^2 - H_\infty^2)s^3$$
In our units $$H(s)^2 - 1 = 0.443s^3$$ Incoming light, by its wavelengths, tells you its stretch factor. So by the same token it tells you the distance expansion rate H(s) at the time it was emitted.
$$H(s) = \sqrt{0.443s^3 + 1}$$
  • #98
So imagine you are visiting some astronomer friends at an observatory and they are doing spectroscopy (wavelength measurement) on the light coming in from a distant galaxy. One of them mentions that the redshift is about 1. That means a stretch factor of two.
So ...two cubed is eight.
So you can casually remark to your astronomer friends: "The Hubble growth rate back then when the light was emitted must have been a little over twice the longterm rate."
Or on another occasion they may have been studying a cluster of galaxies and happen to mention that the incoming light had redshift of about 2. That means a stretch of three.
And you think...three cubed is 27.
And 27 times 0.443 is about twelve.
12+1 = 13, and the square root of 13 is 3.6.
I gather you are amazingly good at doing arithmetic in your head! So then you casually remark to one of your friends, "hmmm...when the light from that cluster was emitted expansion must have been at between 3 and 4 times the longterm rate."
  • #99
I like the simple form of what you have, but I think you should use the traditional scale parameter a = 1/s. It's what people will recognize, though the equation comes out a little messier. Interestingly, H = (ds/dx)/s = -(da/dx)/a, so that part doesn't change form much when you choose between s and a. The next question is, does one simply use s or a as their independent variable, or switch to the more conventional use of x? Since the equation you write has a closed-form solution when you switch to the x variable, there's probably not much lost in doing that, and the gain is being able to talk about time instead of scale. Not that this is automatically a good thing-- as you point out, scale (or stretch) actually has a more direct connection with observed redshifts, whereas time is always awkward! I actually think we should talk about scale and not time (so we don't say the recombination era was at 400,000 years, we say it was at a scale parameter of 1/1000, or a stretch of 1000), so it might even be better to not change the independent variable.
I don't know how the PF Insights section works, so I can't comment on that. Maybe I should have a look at that section, I'm not familiar with it.
  • #100
Thanks for sharing your thoughts, Ken! It's really helpful to have some feedback. I'll keep your comments in mind and hope others will respond as well.
Ken, occasionally we need an informal name for the unit time (17.3 billion years in Earth terms) and I have gotten used to thinking of it as a universe Day. How do you think that would work, and should the abbreviation be Uday or just Day with a capital? Maybe the context will be enough to distinguish that time unit from ordinary 24 hour days. Here's an example where the corresponding distance lightDay would come up in discussion:
==quote from an earlier post==
We were thinking of an example where some light came in with stretch factor 5, from a galaxy back in the time when distances were 1/5 what they are today. ...
... suppose now we ask how far that galaxy is now? How far has this flash of light traveled from its source? (on its own and aided by expansion).
This is a job for the "number empire" integrator. We integrate from s=1 as far as the incoming stretch factor s=5.
===endquote==
You just touched on the "change of variable" idea, I think, and so may have been expecting this: the distance traveled formula, with a change of integration variable
$$\int_{x_{em}}^{x_{now}} s(x)cdx = \int_1^5 \frac{ds}{H(s)} = \int_1^5 \frac{ds}{\sqrt{.443s^3 + 1}}$$
I don't know if it fits in a PF Insights piece, but ds/dx = (-a'/a2) = -s(x)H(x)
so that dx = -ds/(sH)
and the integrand changes from s(x)dx to -ds/H(s)
Maybe that step is worth including.
  • #101
Marcus, I will comment more fully later, but your Udays and especially light-Udays raise some concerns. A light-day has an established meaning in Physics and there is some confusion potential. Secondly, your Uday is a very long, non-cyclic time and perhaps a word that has such connotations would have been better; something like a Universal Time Constant. This specific one would not abbreviate well, because UT and UTC have already been established. Perhaps ##U \tau##?
Us engineers are used to ##\tau## for time constants. :)
  • #102
Incidentally, I have a suggested minor change of form for your main equation for H(s). Instead of the coefficient 0.443, which occupies a somewhat arbitrary place, take its inverse cube root, which is 1.31, and place it under the s in your equation. Then 1.31 has the interpretation of "the stretch factor when the effective mass density of dark energy equals that of actual mass", so is a number that itself carries a meaning. Or, if you switch to a, take the inverse of 1.31 and that's the scale parameter when dark energy took over the lead. It's in the same spirit as your Uday parameter, just a meaningful scale for the stretch factor instead of a scale for the time parameter. I wouldn't recommend redefining the scale of s just to get a universal form for the equation, because s (or a) already has a unique meaning that relates directly to redshifts as you know, but this new form at least explicitly indicates the scale for s.
  • #103
Hi Jorrie, you could say that we don't have much NEED for a time unit name like Day or Universe Day because we can always talk around it and use a symbol for Hubble time, like 1/H, or refer to the quantity as "our time unit 17.3 billion years".
Even if we do arrive at a unit name we like, we still might not make a lot of use of it. Might only need to use it occasionally.
Still, I'd like to try out some name. You've expressed reservations about Day and Uday. Maybe this other idea would work:
Aeon is a word associated with long spans of time. Roger Penrose has used that and I think also Paul Steinhardt may have used it. Anyway it is used.
So how about a magazine-style article on this simple version of the standard LambdaCDM where the title is
"From Aeon to Zeon"
The title would be just kidding, no need to discuss other people's "aeons", the whole point of the article (and this thread) is to explore introducing a time scale based on the cosmological curvature constant Λ and the eventual longterm distance growth rate H that we get from the curvature Λ.
In effect, the whole thing is about the zeon (whatever we happen to call it).
So the present age of expansion is 0.8 zeon, that's our way of saying "now".
And our distance unit is LZ instead of LY, or lz instead of ly.
And the current expansion rate is 1.2 per zeon, or more precisely 1.201 per zeon
and the longterm distance growth rate is 1 per zeon, which is our unit of expansion rate.
I hope that seems OK to you.
Also wondering how it sounds to Ken G, and others who might be reading the thread!
Likes fuzzyfelt
  • #104
I like the idea of using some version of "eon" for your time unit, you are talking about the single most fundamental long-time unit there is in our universe. Perhaps a "cosmological aeon", rather than aeon or zeon, because it could be abbreviated ca, not a or z. a is the scale parameter, z is redshift, and Z is metallicity, all important cosmological topics.
  • #105
Yea, what about "cosmaeon", still abbreviated ca and lca for distance? It is pronounced just like "cosmeon", but the latter is a trademark in the cosmetics industry. AFAIK, "Cosmaeon" has no established meaning. Aeon and Zeon both have known meanings, the latter in liturgy (http://en.wikipedia.org/wiki/Zeon_(liturgy)).
I'm busy with an article-style write-up, so maybe it could be titled "From Aeon to Cosmaeon".
