Simple Nodal Analysis Problem Solution and Explanation
The discussion focuses on solving a nodal analysis problem using Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL). The user is trying to determine the relationship between voltages V2 and V3, questioning if they are equal due to being in parallel. Clarification is provided that V3 is indeed V2, simplifying the analysis. The correct approach involves recognizing the potential difference across the 4-ohm resistor as V1 - 21, which is crucial for solving the circuit. Overall, the guidance emphasizes reducing the number of variables to streamline the solution process.
Magnawolf
KVL and KCL
Let V = V1 and the Voltage across the 2 ohm resistor be V2 just for reference.
Step 1: KCL @ Supernode: V1/3 + V2/2 + 21/4 + V3/6 = 0
I think my problem is here somewhere. Does V3 = V2 because they're in parallel? Also, am I wrong to say that 21/4 is a current going out of the supernode?
Step 2: V2-V1 = 9 (pretty sure this is right)
I can't get the correct answer. Any help is appreciated.
Magnawolf said:
KVL and KCL
The 2 and 6 Ohm resistors are in parallel so they must share the same potential difference. If V1 is the potential at the top of the 3 Ohm resistor then the potential difference across the 4 Ohm resistor must be V1 - 21.
If you make a supernode of the nodes either side of the 9 V source, then really you need only one voltage variable to write the equation. Suppose you chose v to be that variable (after all it's already specified in the circuit diagram). Then on one side of the source the potential is v and on the other side it's v+9. No need to introduce V2 or V3 etc.
Hi. Your V3 is V2, it's the one and the same node. Keep it as just V2.
The current through the 4Ω is given by (voltage across the 4Ω resistor itself) / 4
So what is the voltage across that 4 ohm resistor? Hint: the expression will involve a subtraction
This. This is what I needed. Thanks so much!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
