Simple relationship equation major headache
The relationship between the variables p, q, and r is that p varies directly with the cube of q and inversely with the square of r. The correct equation representing this relationship is p = k(q^3)/(r^2), where k is a constant. To find the value of k, substitute the given values of p, q, and r into the equation. The provided values are p = 3/2, q = 1/2, and r = 1/3. The final solution yields the equation p = (4q^3)/(3r^2).
Ronb107
The quantity p varies directly with the cube of q and inversely
with the square of r. If p = 3/2, q = 1/2, and r = 1/3, which of the
following equations represents the relationship between p, q,
and r?
Here's what I did...
(3/2)p = (1/2)q^3 / (1/3)r^2
Could not get the answer, which is: p = (4q^3) / (3r^2)
Thanks for your help.
You are quite right to write down an equation of the form p = Aq3/r2, but you have not used the other information correctly. You need to find the value of A such that the given values of p, q and r are a solution to the equation.
and r?
You've got the basic relation right. All that's missing is an unknown constant k. So p=kq^3/(r^2). Just put the given values in for p, q and r and solve for k.
  • · Replies 20 ·
