Simple Special Relativity Problem of Length Contraction
In summary, the problem involves two spaceships traveling in opposite directions at a relative speed of ##1.25 \times 10^8## m/s and determining the length of the second ship as measured in its own rest frame. The solution involves setting out the events and using the Lorentz transform to find the length of the second ship, which is determined to be ##12.5## m. This is the same as undoing length contraction in frame ##O##, where the measured length is ##L_B = v \Delta t = L'_B / \gamma##, giving a length of ##12.5## m.
dchartier
Moved from technical forum, so no template
Hello,
I'm self-studying Ta-Pei Cheng's Relativity, Gravitation and Cosmology. Problem 2.8 is the following:
Two spaceships traveling in opposite directions pass one another at a relative speed of ##1.25 \times 10^8## m/s. The clock on one spaceship records a time duration of ##9.1 \times 10^{-8}## s for it to pass from the front end to the tail end of the other ship. What is the length of the second ship as measured in its own rest frame?​
Rather than just apply straightforward length contraction (which I've gotten burned doing in the past in less simple questions), I decided to solve the problem by setting out the events and using the Lorentz transform. Here's my solution. Is my reasoning sound? Thanks!
__________________________________
We'll place the clock in ship ##A## and let ship ##B## be the other ship passing by. Let frame ##O## be ship ##A##'s rest frame and frame ##O'## be ship ##B##'s rest frame, with frame ##O'## moving at ##v = 1.25 \times 10^8## m/s relative to frame ##O##. Let the two frames' origins coincide at ##t=t'=0## and their axes be parallel. We have two events in frame ##O##, with ##E_0## corresponding to when the front of the ship coincides with the clock (which we will designate as occurring at ##t=0##) and ##E_1## when the rear of ship ##B## coincides with the clock:
\begin{array}{ccccc}
E_0 = (t_0,x_0) = (0,0) & & \mbox{and} & & E_1 = (t_1,x_1) = (\Delta t, 0),
\end{array}
where ##\Delta t = 9.1 \times 10^{-8}## sec.
In frame ##O'##, the front of ship ##B## is at ##x'=0## and the rear is at ##x' = -L'_B##. Because this is ship ##B##'s rest frame, the front and rear positions are constant. In frame ##O'##, the two events correspond to:
E'_0 = (t'_0,x'_0) = (0,0) & & \mbox{and} & & E'_1 = (t'_1,x'_1) = (\Delta t', -L'_B).
\end{array}
Using the Lorentz transform for event ##E'_1##, we have:
x'_1 = -L'_B = \gamma(x - vt) = \gamma(0 - v \Delta t) = -\gamma v \Delta t = -12.5 \mbox{m}.
Ship ##B##'s length is therefore ##12.5## m in its rest frame. Note that this is the same as simply undoing length contraction in frame ##O##, where ship ##B##'s measured length is ##L_B = v \Delta t = L'_B/\gamma##, so ##L'_B = \gamma v \Delta t##.
Looks good to me.
Related to Simple Special Relativity Problem of Length Contraction
1. What is length contraction in the context of special relativity?
Length contraction is a phenomenon that occurs in the theory of special relativity, where the length of an object appears shorter when measured by an observer who is moving relative to the object. This is due to the fact that time and space are not absolute and can change depending on the observer's frame of reference.
2. How is length contraction calculated in special relativity?
The formula for length contraction is L = L0 / γ, where L is the measured length, L0 is the rest length of the object, and γ is the Lorentz factor, which takes into account the object's velocity relative to the observer.
3. Does length contraction only occur for objects moving at very high speeds?
Yes, length contraction is only noticeable for objects that are moving at speeds close to the speed of light. For everyday objects moving at typical speeds, the effect of length contraction is negligible.
4. Can length contraction be observed in everyday life?
No, length contraction is not a noticeable effect in everyday life due to the relatively low speeds at which we and the objects around us are moving. It is only significant in the context of objects moving at extremely high speeds, such as in particle accelerators.
5. How does length contraction relate to the concept of time dilation in special relativity?
Length contraction and time dilation are two sides of the same coin in special relativity. While length contraction refers to the shortening of an object in the direction of its motion, time dilation refers to the slowing down of time for the moving object. Both effects are a result of the relative nature of time and space in special relativity.
