Simple Symplectic Reduction Example
In summary, Homework Equations:We have a Hamiltonian with 2 states and 2 co-states, and we are trying to find the constants of motion. We can reduce the problem down to dimension 2n-2, but the first constant reappears. We can try to solve the problem analytically, but the constant will always reappear. We can try to use numerical methods, but the constants will always reappear. We can try to separate the constants from the dynamics, but it is impossible to completely decouple them.
msparapa
I'm struggling to perform a symplectic reduction and don't really understand the process in general. I have a fairly solid understanding of differential equations but am just starting to explore differential geometry. Hopefully somebody will be able to walk me through this very simple example. Given the following optimization problem:
\begin{equation}\text{min}\;J = \frac{1}{2}\int_0^{t_f} u^2dt\end{equation}
\begin{equation}\dot{x_1} = x_2\end{equation}
\begin{equation}\dot{x_2} = u\end{equation}
Where u is a control variable and we have arbitrary boundary conditions defined. Our control Hamiltonian has 2 states and 2 co-states, thus has dimension 2n.
\begin{equation}H = <\lambda,f> + L = \lambda_1x_2 + \lambda_2u + \frac{1}{2}u^2\end{equation}
\begin{equation}\frac{\partial H}{\partial u} = 0 = \lambda_2 + u\end{equation}
\begin{equation}\dot{x} = \frac{\partial H}{\partial \lambda}\end{equation}
\begin{equation}\dot{\lambda} = -\frac{\partial H}{\partial x}\end{equation}
Through integration, we know the solution has the following form:
\begin{equation}x_2 = \frac{1}{2}C_1t^2 - C_2t + C_3\end{equation}
\begin{equation}x_1 = \frac{1}{6}C_1t^3 - \frac{1}{2}C_2t^2 + C_3t + C_4\end{equation}
And using given boundary conditions, the problem simplifies to a 4 dimensional search for each of the 4 constants (or 5 depending on if final time is free, but let's ignore that for now).
Knowing the following is a constant of motion:
\begin{equation}\int_0^t \dot{\lambda_1} dt = C_1\end{equation}
because
\begin{equation}\dot{\lambda_1} = 0\end{equation}
According to the Marsden-Weinstein reduction theorem, I should be able to reduce the Hamiltonian to dimension 2n-2.
\begin{equation}H = <\lambda,f> + L = C_1x_2 + \lambda_2u + \frac{1}{2}u^2\end{equation}
Yet when I rederive the equations of motion, the constant still reappears.
\begin{equation}u = -\lambda_2\end{equation}
\begin{equation}\dot{x_2} = \lambda_2\end{equation}
\begin{equation}\dot{\lambda_2} = -C_1\end{equation}
According to papers I've read online, I should be able to simplify this optimization problem down in dimensionality, but with the first constant reappearing in the equations of motions, I effectively still have a 4 dimensional search. Keep in mind that I'm assuming I'm using some numerical method to solve this problem, not an analytic procedure. Even though this is an easy problem to solve analytically, I don't care about the solution so much as the method itself. If anybody could help me properly reduce the Hamiltonian, that would be great!
Here's a link to a paper that I'm more or less trying to follow:
http://www.utdallas.edu/~txo140730/papers/SymRedOptCtrl.pdf
Example 5.2 from that paper is precisely what I'm trying to do, although probably through a different method. I'd be happy with either one. They begin with a system of 10 differential equations and are able to reduce it to a system of 7 differential equations. My issue is that I can't completely decouple these integrals and constants from my reduced system whereas literature seems to suggest that I should be able to.
Also the search with the example I gave would only be 2 dimensional, 3 with free final time, instead of 4 and 5 like I mentioned before. This is because we'd have some boundary conditions already defined like a start location, but this is really besides the main point.
Bump. Haven't made any progress.
Ohhh boyy this one was a doozy. 4 years and almost 2 degrees later I can finally answer this question. I'm reviving this ancient thread because it is the first example in google when you search "simple symplectic reduction", and also there are very few examples of applied symplectic reduction out in the wild, so hopefully somebody might find my struggles beneficial. In my original post, I was fine up until Equations 13-15. That is, Equation 12 has been correctly reduced, but there's much more going on under the hood than I initially realized. In a sense, I had successfully applied symplectic reduction, but was not thinking about the resulting BVP correctly. Over the past several years, my understanding of the result has greatly changed.
In my second post on this page, I mentioned I had some difficulties completely decoupling the constants from the original system. That's because, save for some special conditions on the boundary, it is impossible to completely decouple the constants-of-motion from the dynamics. Fundamentally, we're solving a Hamiltonian BVP to indirectly solve the original functional minimization problem. Constants-of-motion have either real physical, or mathematical meaning in context of the original problem and therefore cannot be completely ignored. As a concrete example, say we're in a spacecraft performing an orbit raising manuever. The adjoint of true anomaly is a constant of motion, however the point along the orbit where spacecraft starts and finishes its maneuver is fairly significant in context of the mission and cannot be completely removed.
Are we out of luck? Nope! In trying to discover a compact procedure for application to some real problems and squeezing some benefits out of it, I came up with the idea to separate quantities into two categories: "dynamical" and "non-dynamical" terms. Terms that are dynamical affect the dynamical evolution of a system. Terms that are non-dynamical... well... do not affect the dynamics. Starting off with the original problem:
\begin{aligned}
\min J &= \frac{1}{2} \int_{0}^{t_f} u^2 dt \\
\text{Subject to} : \dot{x}_1 &= x_2 \\
\dot{x}_2 &= u \\
x_1(t_f) &= x_{1f}
\end{aligned}
Plus some other boundary conditions, but I'm only including 1 to illustrate a point and make things too cluttered. Adjoining these to the problem, we get the equivalent functional:
\min J = \frac{1}{2} \int_{0}^{t_f} u^2 + \lambda_1(\dot{x}_1 - x_2) + \lambda_2(\dot{x}_2 - u) dt + \nu(x_1(t_f) - x_{1f})
3 Lagrange multipliers were added: ##\lambda_1##, ##\lambda_2##, and ##\nu##. ##\lambda_1## and ##\lambda_2## are dynamical, whereas ##\nu## is non-dynamical. This is because the ##\lambda##'s will show up in the dynamics but ##\nu## will not. Perturbations in ##\nu## will not affect how the system evolves over time. Following my original procedure in the first post, our dynamical system is:
\begin{aligned}
\dot{x}_1 &= x_2 \\
\dot{x}_2 &= u \\
\dot{\lambda}_1 &= 0 \\
\dot{\lambda}_2 &= -\lambda_1
\end{aligned}
So the ##x##'s and ##\lambda##'s, at this point, are the dynamical states for our system. Hold up, ##x_1## doesn't appear anywhere in the dynamics, so wouldn't that be non-dynamical? And ##\lambda_1## is a constant-of-motion, so is it even a state? It's not a coincidence these facts come in two's, and it's also not a coincidence these states are "adjoint" to one-another, i.e. we don't notice the same thing with ##x_i## and ##\lambda_j## for ##i \neq j##. This all agrees with Noether's theorem. Symplectic reduction requires we get rid of both ##x_1## and ##\lambda_1##. Using ##q_1 = x_1## and ##C_1 = \lambda_1## so we come to my original Eq. 12
H = C_1 x_2 + \lambda_2 u + \frac{1}{2}u^2
Which generates the following system
\begin{aligned}
\text{non-dynamical states} : \; \dot{q}_1 &= x_2 \\ \hline
\text{dynamical states} : \; \dot{x}_2 &= u \\
\dot{\lambda}_2 &= -C_1
\end{aligned}
##C_1## is a dynamical parameter in the sense that small perturbations affect how the system evolves, therefore causing changes in ##x_2## and ##\lambda_2##, which then causes changes in ##q_1##. ##q_1## is non-dynamical because, small perturbations to ##q_1## do not affect anything, other than itself. ##q_1## is a symmetry for the system, and in fact all non-dynamical states are symmetries. Not all symmetries are non-dynamical states, however. In other work, people allude to the fact that ##\dot{q}_1## is solved via quadrature rules, but I've never seen an actual implementation of this. By restricting my definition of a non-dynamical state to be a subset of a symmetries, I was able to write my own general purpose BVP solvers https://github.com/Rapid-Design-of-Systems-Laboratory/beluga/tree/master/beluga/bvpsol for the specific intent of solving Hamiltonian BVPs which have been reduced symplectically. Examples "R2", "R8", and "R18" within the https://github.com/Rapid-Design-of-Systems-Laboratory/beluga/tree/master/beluga/bvpsol/tests are real reduced problems and though they are not symplectic, the resulting BVP structure is identical to symplectic BVPs. To anyone who digs into the code, you'll see that for the BVP solver to take full advantage of our structure here, we need to specifically tell it what is dynamical and what is non-dynamical. I'm publishing a paper on these BVP solvers in ~2 months and will edit this post once it's out.
For those who want to dig deeper into the mathematics behind this, in my framework, trajectories evolve on a principal ##G##-bundle. I'm confident in the structure of my BVP solvers, but rephrasing problems to make use of it remains a challenge. I believe Lie-Poisson mechanics is the correct setting to fully exploit the Hamiltonian system and pose it as a BVP with dynamical and non-dynamical states, but this is ongoing.
Likes jim mcnamara
Related to Simple Symplectic Reduction Example
What is simple symplectic reduction?
Simple symplectic reduction is a mathematical technique used in classical mechanics and symplectic geometry to simplify the study of a system with symmetries. It involves reducing the dimension of a symplectic manifold by identifying and eliminating certain degrees of freedom.
How is simple symplectic reduction used?
Simple symplectic reduction is used to simplify the equations of motion of a mechanical system by removing redundant variables. This makes it easier to analyze the behavior of the system and find solutions.
What is an example of simple symplectic reduction?
An example of simple symplectic reduction is the reduction of a 3-dimensional harmonic oscillator to a 2-dimensional system with the same dynamics. This is achieved by identifying a symmetry in the system and eliminating the corresponding degree of freedom.
What are the benefits of using simple symplectic reduction?
Simple symplectic reduction can greatly simplify the study of a mechanical system, making it easier to understand and analyze. It can also reveal underlying structures and symmetries that may not be apparent in the original system.
Are there any limitations to simple symplectic reduction?
Simple symplectic reduction is only applicable to systems with certain symmetries, and it may not always be possible to identify and eliminate the relevant degrees of freedom. Additionally, the reduced system may not fully capture all of the dynamics of the original system.
  • Differential Equations
