Simple Vector Problem - Finding the x-component
  • Thread starter Thread starter Nulligan
    Vector
To find the x-component of a velocity vector at 45 degrees below the positive x-axis with a y-component of -29, the correct approach involves using trigonometric functions. The initial calculations were incorrect due to a misunderstanding of the sine function application. The x-component can be derived from the equation Vx = |V|Cos(Theta) after properly determining the magnitude of the vector. For a vector moving in the negative x-direction at 7.0 cm/s, the x-component is -7.0 cm/s, and the y-component is 0, confirming the direction of the vector. Clarifications on angle usage and direction are essential for accurate component calculations.
Nulligan
A velocity vector 45 below the positive x-axis has a y-component of - 29 .
What is the value of its x-component?
Vx = |V|Cos(Theta)
Vy = |v|Sin(Theta)
Theta = -45 degrees
y-component: -29 = xSin(-45) ... where x is the magnitude of the vector
x = Sin(-45) / - 29
...x = 0.2438
So |V| = 0.24~
Vx = (0.24)Cos(-45)
...=0.171
Says it's wrong, and I don't know where to go now. Am a bit embarassed asking for help with a simple problem like this :\
Oops sorry, nevermind, I realized that in Step 2 I should have divided by Sin(-45)
apologies!
Find x- and y-components of the following vectors
v = 7.0 cm/s, negative x-direction
Vx = |V|Cos(Theta)
Vy = |v|Sin(Theta)
I'm a bit stuck here. I slotted in 7cm/s for |v| but how do I find the components if I'm not given an angle or graphical representation?
It says 'negative x direction'. I think that means it points along the x-axis in the, uh, 'negative' direction. Are you sure you don't want to rethink posting this question?
I thought of that after I posted it and came up with -1, 0 as the x,y components [using cos180 and sign 180) which was still wrong. it's late so I wasn't thinking clearly :P
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
