Simplification of a Force and couple system Wrench Problem
7Lions
I understand 90% of the problem and how to do it, I just can't wrap my head around how they managed to get 0.3sin30 for that one side in the problem.
Figured it out, thanks :P
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
