Simplified diffusion-convection model w/ Rayleigh-Taylor unstability
  • Thread starter Thread starter TboneWalker
    Model
The discussion centers on creating a phenomenological model for convection in a fluid with a negative concentration gradient, particularly focusing on Rayleigh-Taylor instability. The user aims to develop a one-dimensional approximation to predict concentration distribution over time, considering velocity vectors related to density gradients. However, they encounter challenges due to the inherently three-dimensional nature of the problem, where heavier fluid descends as lighter fluid ascends. Recommendations include consulting Chandrasekhar's "Hydrodynamic and Hydromagnetic Stability," which addresses the Rayleigh-Taylor instability analytically. The user acknowledges the limitations of a one-dimensional approach but seeks a way to approximate the effects through a simplified model.
TboneWalker
I am attempting to make a simple phenomenological model of convection in a fluid with a negative concentration gradient. The heavier fluid overlaying light fluid will under many conditions cause a so called Rayleigh-Taylor unstability, and the denser fluid will move downwards as a result. I've been trying to make a one-dimensional approximation of this effect that can predict concentration distribution over time. My first thought was to have a velocity vector that was in some way related to the density gradient, such as
v = constant * (dc/dx)^n
or
v = f(mu) * (dc/dx)^n
mu: viscosity
Im stuggling to find litterature on this, except for numerical solutions of 2D and 3D problems. My hope was to in some way get an average of 2D and 3D effects respresented in the 1D solution. Any thoughts or helpful advice?
I don't see how you can have a 1-D system where this occurs, since as the (say) heavy fluid falls, the light fluid rises. It's a fundamentally 3D problem.
Chandrasekhar's book "Hydrodynamic and Hydromagentic Stability" is the essential book for this problem. The Rayleigh-Taylor instability is solved analytically in section 10.
I know that this convection can not physically happen in one dimension,
I just though it would be possible to approximate a formulation through a 1D equation, that in some way would give us an area-averaged density as a function of height and time...
Thanks for the book tip btw :)
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
