MHB Simplifying Algebraic fraction
To simplify the algebraic fraction 3/90 * (36x+54), clarification was needed on the expression's format. It was confirmed that the expression is equivalent to 3(36x+54)/90. Participants discussed the importance of factoring the expression in parentheses, which aids in simplification. An example was provided to illustrate the process of reducing fractions by factoring and canceling common terms. The original poster expressed gratitude for the clarification, indicating a better understanding of the simplification process.
Spencer23
Hello,
Wondering how to simplify this fraction...
3/90 * (36x+54)
Mathematics news on Phys.org
Hi Spencer23, welcome to MHB!:)
Can you be a little bit more clear about the math expression that you've there, do you mean
1. $\dfrac{3}{90(36x+54)}$ or
2. $\dfrac{3(36x+54)}{90}$?
Its neither of those, I've attatched a picture of a screenshot of the question I've been given. This is why I am having trouble with this one because it isn't in a format I've seen before when working with algebriac fractions.
The form in your attached image is equivalent to the second form given by anemone. This is because the following are equivalent:
$$\frac{a}{b}\cdot c=\frac{ac}{b}$$
For example, consider:
$$\frac{1}{2}\cdot4=\frac{1\cdot4}{2}=\frac{4}{2}=\frac{2\cdot\cancel{2}}{\cancel{2}}=2$$
Can you factor anything from the expression in parentheses?
Also, another example that might be helpful to be used as guidance would be the following:
$\dfrac{6+9}{12}$, it could be simplified further down by rewriting it as $\dfrac{2(3)+3(3)}{3(4)}=\dfrac{3(2+3)}{3(4)}=\dfrac{\cancel{3}(5)}{\cancel{3}(4)}=\dfrac{5}{4}$.
Thanks guys , didnt realize it was the same as the example you gave... understand how its done now! Thank you both!
