MHB Simplifying an Expression (Heather Jean's Question from Facebook)
To simplify the expression - (6y - γ) - 5(-γ + 6y), first eliminate the parentheses, which results in -6y + γ + 5γ - 30y. Next, combine the like terms by adding the coefficients of the same variables, leading to -36y + 6γ. Finally, the simplified expression is -36y + 6γ. This method emphasizes the importance of correctly handling parentheses and combining like terms for simplification.
Sudharaka
MHB
Heather Jean's of Facebook writes:
Simplify,
\[-(6y-\gamma)-5(-\gamma+6y)\]
Mathematics news on Phys.org
Simplify,
Hi Heather, :)
First get rid of the parentheses, then combine like terms(same variable raised to the same power) by adding/subtracting their coefficients, after that combine the constant terms. An example of this procedure can be found >>here<<.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
