MHB Simplifying and expanding expressions
The discussion focuses on simplifying and expanding algebraic expressions in preparation for a test. Participants provide examples, such as combining like terms in expressions like 4x + 7x - 5x, which simplifies to 6x. They also explain the importance of identifying like terms, emphasizing that terms with the same variables raised to the same powers can be combined. Additionally, they discuss the use of brackets in expressions, demonstrating how to expand them, such as (x+y)(x+y) resulting in x² + 2xy + y². Overall, the conversation aims to clarify the processes of simplification and expansion for better understanding.
litchris
I have a test on simplifying and expanding expressions, could someone help me with this. I don't understand the formula and the way you do it
Mathematics news on Phys.org
Do you have specific examples of expressions requiring expansion and/or simplification?
Post a few you have attempted, showing how you tried them yourself ... help us help you.
i tried 4x+7x-5x and 4x^2-2xy-3y^2+6xy+3y^2-x^2 totally confused.
you can sum like terms ...
4x, 7x and -5x are all like terms $\implies 4x + 7x - 5x = 11x - 5x = 6x$
for the second, like terms have the same variables to the same power. like terms have the same color in the expression below ...
${\color{red}4x^2} {\color{blue}-2xy} {\color{green}-3y^2}{\color{blue}+6xy}{\color{green}+3y^2}{\color{red}-x^2} $
I assume you know how to sum terms with the same and/or different signs
Why don't you try and combine them ...
have a look at the link, too
https://www.mathsisfun.com/algebra/like-terms.html
Thanks skeeter this helps
Would you use brackets in your test? In that case...
You multiply each number in the brackets by the other brackets for example: [ (x+y)(x+y) ] would equal [ x2 + xy + xy + y2 ]. Simplifying these expressions would equal x2 + 2xy + y2
Or...
As Skeeter said you combine the expressions from different sides to make a final answer.
4x+7y+2x+9y = 6x + 16y
These are purposely easier just for you to get the gist :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
