MHB Simplifying Expression: $\frac{z^2(w-x)(x-y)}{(w-x)(x-y)(y-w)}$
The discussion focuses on simplifying the expression involving multiple fractions with variables w, x, y, and z. Participants are encouraged to simplify the given expression, which combines terms with common factors in the numerator and denominator. A hint is provided to guide the simplification process. One participant notes that their solution closely resembles another's, indicating a consensus on the approach to the problem. The overall goal is to achieve a more straightforward form of the complex expression.
anemone
MHB
POTW Director
Simplify the expression below:
$\dfrac{w^2(z-x)(z-y)}{(w-x)(w-y)}+\dfrac{x^2(z-y)(z-w)}{(x-y)(x-w)}+\dfrac{y^2(z-w)(z-x)}{(y-w)(y-x)}$
Mathematics news on Phys.org
Hint:
Lagrange's Interpolation Formula
Solution of other:
If $f(a)=a^2$ and if we have the points $(a,\,a^2)=(w,\,w^2),\,(x,\,x^2),\,(y,\,y^2)$ then
$g(a)=\dfrac{w^2(a-x)(a-y)}{(w-x)(w-y)}+\dfrac{x^2(a-y)(a-w)}{(x-y)(x-w)}+\dfrac{y^2(a-w)(a-x)}{(y-w)(y-x)}$
We see that $g(a)$ is identical to $f(a)$.
Since $g(a)$ has degree at most two, if we let
$K=\dfrac{w^2(z-x)(z-y)}{(w-x)(w-y)}+\dfrac{x^2(z-y)(z-w)}{(x-y)(x-w)}+\dfrac{y^2(z-w)(z-x)}{(y-w)(y-x)}$, we have
$K=f(z)=z^2$ and we are done.
my solution is almost the same as anemone has mentioned
we consider the original expression as a function of $z$ with degree 2
if $z=x$ then $f(z)=x^2$
if $z=y$ then $f(z)=y^2$
if $z=w$ then $f(z)=w^2$
so we may conclude :$f(z)=z^2$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
