Simplifying Integration by Parts: Understanding the Solution
Jay9313
∫ln(2x+1) Integrate by parts
I got xln(2x+1)+\frac{1}2{}ln(2x+1)-x+C
The solution is \frac{1}{2}(2x+1)ln(2x+1)-x+C
I know the answers are the same,but it's bugging me that I can't simplify the first answer I got to the second answer. Can someone explain it to me?
Look at the first two terms of your answer. Is there a common factor there that you can pull out?
ln(2x+1) But I don't see how that will help?
Oh, you can pull the term out, substitute your x from your u substitution, combine some terms, and you get it! Thanks!
Glad I could help :)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
