Simulation of a Gaussian beam in an optical waveguide
The discussion focuses on simulating a Gaussian beam in a circular cross-section optical waveguide using MATLAB. The user is familiar with the theoretical aspects of optical fiber modes and seeks numerical techniques for simulation. Group velocity dispersion is acknowledged, and the fiber has a step index profile, though bending effects are not currently considered. The user is primarily interested in the mathematical foundation for starting the simulation. References to external resources and models are provided to assist in the simulation process.
Aniket1
I am trying to simulate a Gaussian beam through an optical waveguide having a circular cross-section in matlab. I am familiar with the theory of modes in an optical fiber and can analytically calculate the evolution of the beam by breaking down the beam into a sum of infinite modes.
However, I wish to know if there is any numerical technique to simulate the same process numerically.
Thank you.
Science news on Phys.org
Is group velocity dispersion considered? Bending radius? Fiber cladding? What are your objectives?
Yes. Group velocity dispersion is considered. The fiber has a step index profile (constant refractive index inside the core and cladding with a small difference between their values). I'm not considering the effect of bending right now. I only want to get an idea of how to start with the simulation in terms of mathematics.
Thank you
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
