Singing in Helium: How Density Affects Resonance Frequency
When singing in helium, the density of the medium affects the resonance frequency of the vocal folds. The original frequency of 500.0 Hz will change due to the lower density of helium, which alters the speed of sound in the medium. As the velocity of sound increases in helium, the wavelength will also change, leading to an increase in frequency. The relationship between velocity, frequency, and wavelength is governed by the equation V=fw, where changes in one variable affect the others. Ultimately, inhaling helium results in a higher pitch due to these changes in resonance frequency.
azatkgz
When you sing, the vocal folds in your throat act as a resonating cavity (one open end, one closed end) which allows only certain frequencies. Suppose you try to sing a pure tone which is detected by a microphone and measured to have a frequency 500.0 Hz. This is the resonance frequency of the vocal folds in your throat, which only depends on the tension and mass of the flesh in your vocal folds. If you now replace the air of density 1.000 kg/m3 with helium of density 0.1640 kg/m3, what frequency will the microphone measure? Provide a graphical representation of the standing waves in your throat. You may assume that the bulk modulus remains constant in the two cases, and that only the density changes.
I think if we change the medium to helium,it will change only wavelenth.
So Frequancy remains constant.
If the speed remains constant then the frequency will change...
V=fw
V-velocity
f-frquency
w-wavelength
I don't know if the speed changes or not though, my intuition says that the frequency will increase because when you inhale helium your pitch of your voice increases
That's not all that will change, it will sound hilarious now. :-p
But seriously, as ||spoon|| notes, if wavelength changes without velocity changing at the same time, frequency has to change.
Then if we change the medium velocity will change,right?
Velocity of sound wave in the should be faster.
From V=fw
If velocity increases then wavelength also.Frequancy remains constant.
Is it Right?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
