Single ended audio amplifier why need DC block
A DC block is essential in single-ended audio amplifier configurations to prevent DC current from flowing through the speaker, which can lead to wasted energy and potential damage. When connecting a double-ended circuit as single-ended, shorting the negative output to ground can disrupt the DC balance, causing audio muting. The DC block allows the amplifier to operate without stressing the output by maintaining low impedance to ground. In balanced output systems, the inverting speaker connection can cancel out DC offsets, but this is not the case in single-ended setups. Understanding the role of DC blocking is crucial for optimal amplifier performance and speaker protection.
spid3rx
Hello all,
This is my first post in this forum. Hope can get some constructive help from the community.
I did some testing with some radios which is actually a double ended circuit (BTL), meaning it has the spk+ and spk- port.
When I want to connect it as a single ended circuit, meaning the spk - short to ground, the audio is muted. The only way for it to work is by adding a capacitor in line with the spk+ which is the DC blcok. I search through the internet and found similar information saying that the DC block is required in order to work.
Can I know why ? what is the reason behind?
Thanks, appreciate the view and help.
Any DC current running through your speaker coil is wasted energy, for a start - it's not part of what you want to hear.
Afaik, most amplifiers - even double ended ones - use DC blocking - or they will use feedback to eliminate any DC current through the speaker. Connecting one amplifier outlet via a very few ohms to ground will totally upset the DC conditions; the two outputs of a balanced output could be varying (in antiphase) between V++ and 0V (or between V++ and V--) and neither of the output halves is expecting to supply a lot of DC current to ground. Give the poor thing a break!:smile:
Thanks sphiecentaur.
The main reason for single ended connection, the audio amplifier sees a low impedance that is going to ground hence causing stress in order to provide higher current. Correct me if I am wrong :)
For BTL, even without the DC block, the speaker will work, is it been cancel off by the inverting spk- ?
This is a good information i manage to read through internet, just for comunity sharing :)
http://www.audiodesignline.com/howto/205601397;jsessionid=3FGICYURRJYADQE1GHOSKHWATMY32JVN?pgno=2
I hope these were not old valve radios they can present lethal voltages.
More recent, but still old, transistor radios usually had a transformer coupling to the speaker. In this case a blocking capacitor is not needed.
If you are talking about muting at the speaker output jack, some of these automatically switch out the internal speaker when you connect an external one.
its not old radio :)
I am not trying to mute the speaker output jack, instead I want the audio. this can be done with the help of the dc block.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
