Singlet/Triplet state mixing question
  • Thread starter Thread starter pfollansbee
    Mixing State
pfollansbee
Hey guys!
I am trying to show how singlet and triplet states mix via spin-orbit coupling, but I am having some trouble.
I've gotten most of the way through, but I am stuck on how an operator works. Sadly, I think my poor basis in quantum is going to show right here.
My starting point...
\left(s_{1z}-s_{2z}\right)\left|0,0\right\rangle =\hbar \left|1,0\right\rangle
The book I am looking at sort of skims past this and assumes that I have a clue what is going on here.
So I know
\left|0,0\right\rangle =\frac{1}{\sqrt{2}}\left\{\left|-+\right\rangle -\left|+-\right\rangle \right\}
s_z=\frac{\hbar }{2}\left\{\left|+\right\rangle \left\langle +\right|-\left|-\right\rangle \left\langle -\right|\right\}
and I am thinking that
\left(s_{1z}-s_{2z}\right)\left|0,0\right\rangle = \frac{1}{\sqrt{2}}\left(s_{1z}\left\{\left|-+\right\rangle -\left|+-\right\rangle \right\}-s_{2z}\left\{\left|-+\right\rangle -\left|+-\right\rangle \right\}\right)
After this it becomes a giant mess. Basically it hinges on my inability to evaluate things of the form
\left|+\right\rangle \left\langle +|-+\right\rangle
I am thinking that this is heavily reliant on some other basics as well. In determining the s_z spinor I am not sure how to evaluate something like
\left\langle +|+\right\rangle \left\langle +|+\right\rangle - \left\langle +|-\right\rangle \left\langle -|+\right\rangle
which is supposed to equal one and
\left\langle +|+\right\rangle \left\langle +|-\right\rangle - \left\langle +|-\right\rangle \left\langle -|-\right\rangle
which is supposed to equal zero
I was hoping that someone here would be able to help me figure out how
and the above evaluations. Thanks a whole bunch!
You have two sub-systems. A convenient way to take care of this is the tensor product:
You write e.g. : | ++>=|+>\otimes|+> and s_{1z}=s_z \otimes 1.
The action of the operator on the state then becomes:
s_{1z}|++>=s_z|+>\otimes 1|+>=\frac{\hbar}{2}|++>.
I hope that gives you an idea of how to proceed.
Yes! That definitely will help me on my way. Unfortunately, I am still having some difficulty.
This is the part that is giving me trouble.
s_z|+\rangle ⊗ 1|+\rangle
When I took a quantum class we never used the +/- notation, we were trained with α and β, but it seems that most modern books are using the +/-. Because of this, I am not very familiar with their mathematical meaning.
If you could be so kind as to help me solve: s_z|+\rangle?
Here's my current process:
If s_z=\frac{\hbar }{2}\left[\left|+\right\rangle \left\langle +\right|-\left|-\right\rangle \left\langle -\right|\right]
then s_z\left|+\right\rangle =\frac{\hbar }{2}[|+\rangle \langle +|+\rangle - |-\rangle \langle -|+\rangle]
This is where I am stuck (If I am even correct to this point... for all I know, I may not be clear on the proper way to handle the operator)
Does <+|+> = 1 and <-|+> = 0? because that would make sense for getting \frac{\hbar }{2}|+\rangle
(would this also mean that <-|-> = 1? or would it be -1?)
If so, how do I get the 0 and 1? If not, then how do I evaluate these correctly?
Thanks again!
yes, + and - correspond one to one to alpha and beta.
They are defined to be the eigenstates of s_z.
The two states are orthogonal to each other (like any two eigenstates of a hermitian operator belonging to two different eigenvalues, namely that of s_z) whence <+|->=0 and <+|+>=1.
I think one alternative way of seeing things is to realize that you're working within a finite state space (4 dimensional) and that you can write down these operators explicitly. Take a look at this page:
http://electron6.phys.utk.edu/qm1/modules/m10/twospin.htm
I don't get what your question has to do with SO coupling though.
Thanks a bunch! After having a good think about it, it all makes perfect sense now and I now know exactly how the s_1z-s_2z operator works. I will post how it relates to spin orbit coupling and singlet triplet mixing a little later once I have written it out in an understandable manner.
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
