Sinusoidal Radiation Statements (T/F)
Sinusoidal radiation involves several key principles, including the relationship between electric and magnetic fields, which are perpendicular to each other and to the direction of radiation propagation. The source of sinusoidal radiation is oscillating charges, and the radiation pattern does change with distance and time. The electric and magnetic fields do not have the same magnitude, as described by the equation E = vB. The propagation direction can be determined using the right-hand rule. Understanding these concepts is crucial for correctly answering related questions.
o79
True or False for each
Equations for sinusoidal electromagnetic radiation
Which of the following are true for sinusoidal radiation?
1) The electric field and the magnetic field have the same magnitude at the same point in space.
2) The electric field is perpendicular to the magnetic field.
3) The source of the radiation is oscillating charges.
4) The radiation pattern does not change with distance.
5) Oscillating charges are not accelerating.
6) The radiation travels perpendicular to the electric field.
7) The radiation travels perpendicular to the magnetic field.
8) The propagation direction of the radiation can be determined from the right hand rule.
9) The radiation pattern does not change with time.
Hi, I am having trouble with this problem. I have selected 1, 2, 3, 7, 8, however, it is marked as incorrect and would appreciate some guidance.
I have realized my mistakes. The radiation propagates perpendicular to both the electric AND magnetic fields. Also, since E = vB, electric and magnetic fields do not have the same magnitude.
I am glad you found your mistakes and you don't need out help.
For future reference: If you have trouble with problems, please understand that we cannot offer any unless we know what you think about the problem and what you tried.
Please read, understand and follow our homework guidelines, especially item 4, here
https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
