Sketch output for 2-input AND gate
The discussion revolves around sketching the output waveform for a 2-input AND gate based on provided inputs. The fundamental equation for the AND gate is x = AB, indicating that the output is high only when both inputs A and B are high. Participants confirm that the output waveform should reflect this condition, emphasizing that the AND function can be viewed as a multiplication of logical values. Clarifications on how to represent the multiplication of waveforms are also discussed. Overall, the key takeaway is that the output is high only when both inputs are simultaneously high.
sami23
Sketch the output waveform for the given circuit and inputs (see attachment)
For AND gate: x = AB (multiply the inputs to get the output)
attached is my sketch.
How to multiply 2 waveforms?
Your 2nd sketch looks correct. The AND of A and B will only be high if both are high at the same time.
I guess you could call the AND function a multiplication, if you multiply the logical values (0,1). You can only get a 1 out of that multiplication if...
thanks for the clarification!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
