Sky temperature profiles and black body radiation
In summary, a sky temperature profile is a graphical representation of how the temperature of the Earth's atmosphere changes with altitude. It is important in understanding black body radiation, which is the electromagnetic radiation emitted by an object due to its temperature. Sky temperature profiles and black body radiation are related because they show how the temperature of the atmosphere affects the amount and type of radiation that is emitted and absorbed by the Earth. The sky temperature is colder at higher altitudes due to less dense air and less direct sunlight. Scientists use sky temperature profiles to study climate change by tracking changes in the Earth's temperature over time and comparing it to historical data.
lostminty
82
I want to know, excluding the sun with an appropriate boundary, whether it is possible for the balance of bbr to be positive for outerspace rather than on earth? I am thinking of a half convex with an active polariser across-the outer surface which allows through most radiation below the temperature you desire.
Astronomy news on Phys.org
If this is in the wrong sub forum let me know.
Related to Sky temperature profiles and black body radiation
1. What is a sky temperature profile?
A sky temperature profile is a graphical representation of how the temperature of the Earth's atmosphere changes with altitude. It shows the temperature at different altitudes, starting from the Earth's surface and going up into the atmosphere.
2. What is black body radiation?
Black body radiation is the electromagnetic radiation emitted by an object because of its temperature. It is a continuous spectrum of radiation that depends only on the temperature of the object and not on its composition or structure.
3. How are sky temperature profiles and black body radiation related?
Sky temperature profiles are important in understanding black body radiation because they show how the temperature of the atmosphere affects the amount and type of radiation that is emitted and absorbed by the Earth. Black body radiation is also used to calculate the temperature of the Earth's atmosphere at different altitudes, which can be compared to the sky temperature profile.
4. Why is the sky temperature colder at higher altitudes?
The sky temperature is colder at higher altitudes because the air is less dense, meaning there are fewer molecules to absorb and retain heat. In addition, the further away from the Earth's surface, the less direct sunlight reaches the atmosphere, resulting in lower temperatures.
5. How do scientists use sky temperature profiles to study climate change?
Scientists use sky temperature profiles to track changes in the Earth's temperature over time, which can help them understand the effects of climate change. By comparing current sky temperature profiles to historical data, scientists can determine if the atmosphere is warming or cooling and how this is impacting the Earth's climate.
