cianfa72
- 2,818
- 298
- TL;DR Summary
- About SL(n,R) as Lie group with the smooth structure as regular submanifold of GL(n,R)
Hi,
consider the group ##SL(n,\mathbb R)##. It is a subgroup of ##GL(n,\mathbb R)##. To show it is a Lie group we must assign a differential structure turning it into a differential manifold, proving further that multiplication and taking the inverse are actually smooth maps.
With the indentification ##\mathbb M_n \cong \mathbb R^{2n}## one can see that ##GL(n,\mathbb R)## is an open submanifold of ##\mathbb M_n## (it is the preimage of an open set through the determinant map ##d## that is continuous). Then by mean of Regular level set theorem, ##SL(n,\mathbb R)## is actually a regular submanifold of codimension 1.
Btw, if one restricts the domain of the determinant map ##d## to the subset ##GL(n,\mathbb R)##, it is continuous as well. Therefore the preimage of the closed set ##\{1\}## under the "restricted determinant map" gives a closed set in ##GL(n,\mathbb R)##. It isn't in general a closed subset of ##\mathbb M_n \cong \mathbb R^{2n}##.
Is the above correct ? Thanks.
