Stargazing Small angle lunar haloes
  • Thread starter Thread starter Bandersnatch
The discussion centers on the observation of small lunar haloes, specifically those within a 4-6 degree radius from the Moon, which included a bright central disc and outer circular rings. The cause of these smaller haloes is attributed to moonlight interacting with water droplets and ice crystals in the atmosphere, with their size varying based on the thickness and density of moisture particles. Participants speculate about the possibility of a corona, which forms when droplets are uniform in size, and discuss the relationship between droplet size and the angular size of the corona. The conversation also touches on diffraction phenomena and how non-spherical aerosols can create non-circular rings. Overall, the thread highlights the complexities of atmospheric optics related to lunar observations.
Bandersnatch
Yesterday night I watched the Moon. It was surrounded by a set of haloes, relatively small in diameter. I didn't take a picture.
I understand the cause of the 22-degree halo, but I don't know what causes those smaller haloes.
These were approximately within 4-6 degree in radius from the Moon. The central one was disc-like, bright throughout the area. The remaining one or two (I can no longer remember clearly) outer ones were circular, separated by darker gaps.
The sky was clear, and the effect persisted throughout the night.
Astronomy news on Phys.org
A couple possible explanations:
Those multiple halos were do to the Moon light passing thru both water droplets (fog) and ice crystals in the atmosphere; or passing thru either one of these that was present at different altitudes.
Cheers,
Tom
Likes Bandersnatch and Klystron
The haloes will vary in size according to the thickness and density of the cold air and moisture particles in the regen, whether they are frozen or not; it's just a matter of refraction and defraction. If you could observe the haloes from a longer distance, they would be more defused and larger in size.
Likes Bandersnatch
I wonder if you saw a corona:
https://www.atoptics.org.uk/droplets/cormoon.htm
https://www.atoptics.org.uk/droplets/corona.htm
I've seen similar rings on occasion- AFAIK, they form when the intervening droplets/ice crystals are very uniform in size.
Likes Tom.G and Bandersnatch
Thanks everyone. Corona does look similar.
Have any of you seen it worked out somewhere how the droplet size relates to the angular size of the corona, or how that outer ring forms (I'm assuming it's something similar to the rainbow mechanism). In a textbook maybe? I'd like to nerd it out a little.
I think it's a straight diffraction problem, similar to powder diffraction or scattering by colloids. IIRC, the angular diameter of the rings depends on the droplet size, the ring spacing depends on the average spacing of droplets, and multiple rings indicate good monodispersity.
I don't think it's a case of Mie scattering (that's responsible for backscattering phenomena like glories)
Apparently non-spherical aerosols (like pollen) produce non-circular rings:
https://www.atoptics.org.uk/droplets/pollen1.htm
Likes Bandersnatch
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
11K
