Small-florida-community-aims-for-energy-independence
  • Thread starter Thread starter dlgoff
A small Florida community is pursuing energy independence through a large solar panel array consisting of 700,000 panels spread over 800 acres. Florida Power & Light (FPL) has significantly invested in solar energy, installing around 11 million panels statewide, which now generate nearly 9 percent of the grid's power. While FPL has built 10 megawatts of lithium battery storage, it is insufficient for nighttime power needs, which are supplemented by a natural gas plant. The solar farm's peak production aligns with Florida's peak power demand, reducing the necessity for extensive storage solutions. The discussion emphasizes the importance of diverse energy sources in planning for future energy needs.
dlgoff
I thought of Old Jim (Jim Hardy), who worked at a Florida power plant, when watching a PBS television program this evening about this Solar panel array:
Image compliments of https://www.pbs.org/newshour/show/s...dependence-by-harnessing-the-power-of-the-sun
  • Wow
Likes Master1022, Klystron and berkeman
Wow, big array. Did they say how many acres it covers?
It's 700,000 panels on about 800 acres of land. So, it is a very large solar field.
FPL is very serious about solar.
Matt Valle is FPL's vice president of development.
Since the installation of these arrays at Babcock Ranch in 2016, the company has gone big on solar power. Statewide, it has installed about 11 `million solar panels, generating nearly 9 percent of what it puts into the grid. The big driver is economics. Solar panels are now 80 percent cheaper than they were a decade ago.
I wondered about battery storage for load at night, and found
FPL has built 10 megawatts of lithium battery storage here, but it's not nearly enough to power Babcock Ranch through the night. A natural gas plant fills the gap.
Likes Klystron, dlgoff, russ_watters and 1 other person
Location location location. Florida's peak power demand comes during the afternoon of the hottest sunniest days which coincides with peak solar production. So, because this solar farm is owned by FPL (the local power company), they can use other diverse power plants to supply the community at night, and the need for storage is avoided.
At my son's former residence in Fairbanks, Alaska, the situation is very different.
When we plan the energy future for a whole country or a whole continent, an important word is diversity. I'm confident that @dlgoff and @Astronuc and @berkeman understand that, but I like to keep hammering that point home at every opportunity.
Likes Averagesupernova, dlgoff, russ_watters and 1 other person
Looks like our coal fired pant near Lawrence, Kansas is shutting to help with it's carbon net-zero plan:
https://www2.ljworld.com/news/gener...l-fired-power-plant-just-outside-of-lawrence/
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
