Smart glass as Faraday shielding
Smart glass products can be electrically tuned to switch between mirroring and transparency, potentially offering a novel approach to Faraday shielding against eavesdropping. However, current smart glass technology has limitations, such as slow response times and limited effectiveness across various electromagnetic wavelengths, particularly in radio and microwave ranges. The high resistance of the transparent electrodes used in smart glass hinders its ability to reflect radio frequencies effectively. Additionally, vulnerabilities exist where an adversary could manipulate the glass's state or damage its conductive film. For optimal electromagnetic privacy, constructing a double-walled, windowless screened room with proper ventilation and power supply decoupling is recommended.
hilbert2
Insights Author
TL;DR Summary
Using tunable mirrors as Faraday shielding
Some companies seem to be selling "smart glass" products that can be electrically tuned at will to be either mirroring or transparent, at least in visible wavelengths.
Suppose someone were to Faraday shield a room to prevent van Eck phreaking or whatever kind of eavesdropping from outside, using that type of surfaces as part of the shielding, and make their conductivity/reflectivity change randomly at a very high frequency. Then I guess any signals leaking out would have an additional random high-frequency modulation in them, making them impossible to interpret? That would seem to be even better than normal EM shielding, but a problem is that mobile network signals from phones or computers would become unwanted radio noise when mangled in that way, and possibly disturb everyone else's communications.
This is just a theoretical idea, as the current tunable smart mirrors only seem to reflect EM radiation on a limited range of wavelengths.
I think it is just a liquid crystal device which operates slowly to give a frosted appearance, so cannot respond to high frequencies. I imagine the surface will still reflect light in the usual way so might be subject to eavesdropping.
Some of them actually become mirroring and not just opaque, but there doesn't seem to be much data about the transmittance on a large wavelength range that includes radio and microwave frequencies.
The refractive index of materials, is usually different between optical and radio frequencies.
The thin transparent electrodes (indium) printed on glass have a high resistance. That slows the switching response to applied voltages to microseconds. The high resistance electrodes are very poor at reflecting RF.
Your enemy could radiate your smart glass, with sufficient RF power to lock it in a transparent optical mode, or destroy the conductive film on the glass.
If you want EM privacy, you need to build a double wall screened room without windows, and with a conductively-fitting door. Ventilation will need to be through metal screens. Power supplies must be decoupled.
You could increase security by transmitting one watt of random spread spectrum signal on the outside of the box, to mask the greatly attenuated internal signals that might escape.
Likes berkeman and hilbert2
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
