Snell's law, critical angle & refraction
To determine the critical angle between layers with velocities v_1=1.5 km/s and v_2=1.3 km/s, the relationship sin(θ_c) = v_2/v_1 is used, leading to a value greater than 1, which is problematic. According to Snell's law, the critical angle occurs when the refracted angle θ_2 is 90 degrees, simplifying the equation to sin(θ_c) = n_2/n_1. The confusion arises from the refractive indices, where n is defined as the speed of light in a vacuum divided by the speed in the medium, leading to the conclusion that the velocities correspond to their respective indices. Clarification on the indices and their relationship to velocity is essential for solving the problem correctly. Understanding these principles is crucial for accurately applying Snell's law in multi-layer models.
sveioen
Given a three layer model
v_1=1.5km/s
v_2=1.3km/s
v_3=2.0km/s
Assume a ray goes through layer 1 and hits the interface between layer 1 and layer 2. What is the critical angle?
Snells law
\frac{\sin \theta_1}{\sin \theta_2}=\frac{v_1}{v_2}
To find the critical angle, you normally take \sin \theta_c = \frac{v_1}{v_2}=\frac{1.5}{1.3}. But in this case that means I have to take \sin^{-1} of a value that is over 1! How do I solve this?
n1sin(θ1) = n2sin(θ2)
If θ1 is θc, then θ2 = 90 degrees.
So sin(θc) = n2/n1
So sin(θc) = n2/n1
When I look up Snell's law on Wikipedia it says
<br /> \frac{\sin \theta_1}{\sin \theta_2}=\frac{v_1}{v_2}=\frac{n_2}{n_1}<br />
Why does the subscript change in the n_n ? Isnt v_1=n_1 and v_2=n_2?
Thanks for answering
According to the definition,
refractive index n = c/v. where c is the velocity of light in vacuum and v is the velocity in the refracting medium.
So v = c/n
Or v1 = c/n1 and v2 = c/n2
then v1/v2 = ...?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
