Software for Converting Spectral Density to Modified Allan Deviation
In summary: The power spectral density S_y and the number of tau values used in the integral. ad: np.array ... The modified Allan deviation. Notes .. The function psd2allan() implements the integral by discrete numerical integration via a sum. Parameters ---------- S_y: np.array Single-sided power spectral density (PSD) of fractional frequency
Twigg
483
TL;DR Summary
I am looking for a program or programming library that can take the power spectral density (PSD) of a signal as an input and return it's modified allan deviation as an output.
Mathematically, you can convert between a power spectral density (PSD) and the modified allan variance as follows:
$$\sigma_y^2 (\tau) = \int_0^{\infty} \frac{G_\nu(f)}{\nu^2} \times 32 \frac{(\sin(\pi f \tau/2))^4 \times |\sin(\pi f \tau)|^2}{(\pi \tau f)^4} df$$
I was wondering if anyone knew of a piece of software or a programming library that implements this conversion. I'm working on a project and trying to minimize the amount of code I personally need to maintain.
Definitions:
##\nu##: the center frequency of the signal being studied
##\sigma_y(\tau)##: the modified allan deviation of the fractional frequency deviation, ##y = \frac{\delta \nu}{\nu}##, as a function of time ##\tau##
##G_{\nu}(f)##: the power spectral density of frequency deviations (##\delta \nu##, not ##y##)I have already looked into the program stable32 and python's allantools module. As far as I could tell from reading the documentation, stable32 doesn't do a psd-to-allan feature. The allantools module does have a psd2allan function in it's docs, but whenever I pip install the module and import it, that function simply doesn't appear in the module (all the other documented functions do! :headbang:). I think it must not be implemented yet or something.
Note to mods: I realize this is a programming question, but I felt it belonged more in the statistics subforum since it's so specialized. Feel free to move it if necessary!
One place to check would be the Matlab forums at the math works website. You might get a lead on where else to look or even some implementation that you could port.
I did notice that, however I already tried installing each of the last 3 versions of allantools (2019.9, 2019.7, and 2018.3), which all had the same effect.
I'm on windows, so I run in the terminal:
Code:
pip install allantools==2019.9
python
>>> import allantools
>>> allantools.psd2allan()
and I get as output:
AttributeError: module 'allantools' has no attribute 'psd2allan'
Curiously, the test case I referenced has the psd2allan lines commented out so they must be having trouble with the code or it's not in the allantools.py script.
In the allantools.py there's a comment on unreleased code and psd2allen is listed so I guess you'll have to roll your own or find another library that implements it.
allantools.py:
Allan deviation tools
**Author:** Anders Wallin (anders.e.e.wallin "at" gmail.com)
Version history
**unreleased**
- ITU PRC, PRTC, ePRTC masks for TDEV and MTIE in new file mask.py
- psd2allan() - convert PSD to ADEV/MDEV
- GCODEV
**2019.09** 2019 September
- packaging changes, for conda package
  (see https://anaconda.org/conda-forge/allantools)
Likes Twigg
I looked in the allantools.py and found they do have code for it so maybe you could use that as a basis and roll a better one.
Psd2allan():
def psd2allan(S_y, f=1.0, kind='adev', base=2):
    """ Convert a given (one-sided) power spectral density S_y(f) to Allan
        deviation or modified Allan deviation
    For ergodic noise, the Allan variance or modified Allan variance
    is related to the power spectral density :math:`S_y` of the fractional
    frequency deviation:
    .. math::
        \\sigma^2_y(\\tau) = 2 \\int_0^\\infty S_y(f)
        \\left|sin(\\pi*f*\\tau).^(k+1)./(\\pi*f*tau).^k).^2\\right| df,
    where :math:`f` is the Fourier frequency and :math:`\\tau` the averaging
    time. The exponent :math:`k` is 1 for the Allan variance and 2 for the
    modified Allan variance.
    NIST [SP1065]_ eqs (65-66), page 73.
    a sum.
    Parameters
    S_y: np.array
        deviation S_y in 1/Hz^2. First element is S_y(f=0).
    f: np.array or scalar numeric (float or int)
        if np.array: Spectral frequency vector in Hz
        if numeric scalar: Spectral frequency step in Hz
        default: Spectral frequency step 1 Hz
    kind: {'adev', 'mdev'}
        Which kind of Allan deviation to compute. Defaults to 'adev'
    base: float
        Base for logarithmic spacing of tau values. E.g. base= 10: decade,
        base= 2: octave, base <= 1: all
    Returns
    (taus_used, ad): tuple
          Tuple of 2 values
    taus_used: np.array
        tau values for which ad computed
    ad: np.array
        Computed Allan deviation of requested kind for each tau value
    # determine taus from df
    # first oversample S_y by a factor of 10 in order to avoid numerical
    # problem at tau > 1/2df
    if isinstance(S_y, np.ndarray):
        if isinstance(f, np.ndarray):  # f is frequency vector
            df = f[1]-f[0]
        elif np.isscalar(f):
            # assume that f is the frequency step, not frequency vector
            df = f
        else:
            raise ValueError(np.ndarray, float, int)
    else:
        raise ValueError(np.ndarray)  # raise error
    oversamplingfactor = 4
    df0 = oversamplingfactor * df
    f0 = np.arange(S_y.size * df0, step=df0)
    f = np.arange(df, (S_y.size - 1) * df0 + df, df)
    S_y = interpolate.interp1d(f0, S_y, kind='cubic')(f)
    f = f / oversamplingfactor
    tau0 = 1/np.max(f)  # minimum tau derived from the given frequency vector
    n = 1/df/tau0/2
    if base > 1:
        m = np.unique(np.round(np.append(base**np.arange(
            np.floor(np.log(n)/np.log(base))), n)))
    else:
        m = np.arange(1, n)
    taus_used = m*tau0
    # TODO: In principle, this approach can be extended to the other kinds of
    # Allan deviations, we just need to determine the respective transfer
    # function in the frequency domain.
    if kind[0].lower() == 'a':   # for ADEV
        exponent = 1.0
    elif kind[0].lower() == 'm':  # for modADEV
        exponent = 2.0
    integrand = np.array([
        S_y *
        np.abs(np.sin(np.pi * f * taus_used[idx])**(exponent + 1.0)
               / (np.pi * f * taus_used[idx])**exponent)**2.0
        for idx, mj in enumerate(m)])
    integrand = np.insert(integrand, 0, 0.0, axis=1)
    f = np.insert(f, 0, 0.0)
    ad = np.sqrt(2.0 * simps(integrand, f))
    return taus_used, ad
Likes Mark44 and Twigg
Caveat emptor on that code as there is likely some hidden issue preventing it from being released.
Likes Twigg
Thanks for this!
I ended up writing something quick and dirty from scratch as a stand-in until I find more reliable code, but I think this code you found will have some good hints. I had a few artifacts for large tau that maybe this code addresses. I'll check it out tomorrow.
Thanks again!
Likes jedishrfu
FAQ: Software for Converting Spectral Density to Modified Allan Deviation
What is the purpose of software for converting spectral density to modified Allan deviation?
The purpose of this software is to analyze and convert spectral density data, which represents the frequency components of a signal, into modified Allan deviation data, which is a measure of frequency stability over time. This conversion allows for a more accurate and precise analysis of frequency stability in various applications, such as in atomic clocks and precision measurement devices.
How does the software convert spectral density to modified Allan deviation?
The software uses mathematical algorithms and statistical methods to analyze the spectral density data and calculate the corresponding modified Allan deviation values. This involves integrating the spectral density data and taking the square root of the resulting value to obtain the modified Allan deviation.
What types of data can be input into the software for conversion?
The software can accept data in various formats, such as time series data, frequency data, or power spectral density data. It can also handle different units of measurement, such as hertz or parts per million. Additionally, the software can handle both single-channel and multi-channel data.
Can the software handle large datasets?
Yes, the software is designed to handle large datasets with high precision and efficiency. It uses advanced computational methods to process and analyze large amounts of data in a timely manner, making it suitable for use in research and industrial applications.
Is the software user-friendly?
Yes, the software is designed to be user-friendly and intuitive, with a user-friendly interface and easy-to-follow instructions. It also offers various customization options, allowing users to adjust parameters and settings according to their specific needs and preferences.
