High School Solar Wind Particles, - reaching into Earth's magnetic field?
The solar wind primarily interacts with Earth's magnetic field, resulting in most particles being deflected rather than penetrating deep into the magnetosphere. At 1 astronomical unit (AU), the solar wind's plasma flows at speeds of 250 to 750 km/s with a density of 3 to 10 particles per cubic centimeter. While some particles may reach the magnetosphere, the majority are redirected, with only a small fraction making it deeper into the magnetic field. The pressure exerted by the solar wind at this distance typically ranges from 1 to 6 nPa. Understanding these dynamics is crucial for studying the effects of solar wind on Earth's environment.
Mikael17
TL;DR
Solar Wind particles reaching into Earth's magnetic field ?
How many particles (approximately) from the solar wind reach deep into the Earth's magnetic field every second. Possibly measured in mass?
Astronomy news on Phys.org
What do you mean by "deep"? Most of the solar wind is deflected by the Earth's magnetic field:
When the solar wind encounters Earth, it is deflected by our planet's magnetic shield, causing most of the solar wind's energetic particles to flow around and beyond us. This region that meets and blocks the solar wind is called the magnetosphere.
https://www.jpl.nasa.gov/nmp/st5/SCIENCE/solarwind.html
The Wikipedia article gives some numbers that you could use to calculate the density/flux of the solar wind near the Earth, but before it is deflected by the magnetospnere:
Velocity and density
Near the Earth's orbit at 1 astronomical unit (AU) the plasma flows at speeds ranging from 250 to 750 km/s with a density ranging between 3 and 10 particles per cubic centimeter and temperature ranging from 104 to 106 Kelvin.[45]
On average, the plasma density decreases with the square of the distance from the Sun, see Section 4.2,[46] while the velocity decreases and flattens out at 1 AU, see Figure 5.[46]
Voyager 1 and Voyager 2 reported plasma density n between 0.001 and 0.005 particles/cm3 at distances of 80 to 120 AU, increasing rapidy beyond 120 AU at Heliopause to between 0.05 and 0.2 particles/cm3.[47]
Pressure
At 1 AU, the wind exerts a pressure typically in the range of 1–6 nPa ((1–6)×10−9 N/m2),[48] although it can readily vary outside that range.
The ram pressure is a function of wind speed and density. The formula is
P = m p ⋅ n ⋅ V 2 = 1.6726 × 10 − 27 k g ⋅ n ⋅ V 2 {\displaystyle P=m_{\text{p}}\cdot n\cdot V^{2}=\mathrm {1.6726\times 10^{-27}\,kg} \cdot n\cdot V^{2}}
where mp is the proton mass, pressure P is in Pa (pascals), n is the density in particles/cm3 and V is the speed in km/s of the solar wind.[49]
https://en.wikipedia.org/wiki/Solar_wind
Likes Delta Prime
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 30 ·
  • · Replies 46 ·
11K
  • · Replies 57 ·
