(Solid State) low resistivity dependance on temperature
Minimizing temperature dependence in electronic components is crucial, with constantan being a notable alloy used for temperature-independent resistance. It is suggested that constantan has a low density of lattice defects, as a constant resistance implies a constant scattering time, indicating fewer defects for electrons to scatter off. The alloy's composition of copper and nickel contributes to its low coefficient of resistivity, enhancing electron mobility. Understanding the manufacturing process of constantan may provide further insights into its defect density and resistivity characteristics. Overall, the relationship between lattice defects and resistivity is central to the discussion.
SMC
For some applications it is important to minimize the temperature dependence of electronic components. For example, there is a special alloy called constantan that can be used for temperature independent resistance elements. Do you expect constantan to have a high or low density of lattice defects? Justify your answer.
so i assume it has low density of lattice defects because if resistance remains constant then scattering time is also constant which means that there are no defects for the electron to scatter off of. would this statement be correct?
thank you for any advice you can give me
Certainly the resistivity depends on defect density, but how is Constantan made? Why does it have a low coefficient of resistivity?
well i know constantan is an alloy of copper and nickel which I guess have fairly small nuclei which which increases scattering time and decreases resistivity. I'm not sure I fully understood what you're asking though
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
