Solution check for pH of Strong Acid and Strong Base
  • Thread starter Thread starter pavadrin
    Acid Base Ph
The discussion focuses on calculating the pH after adding 24 mL of 1.00 M NaOH to 25.0 mL of 1.00 M HCl. The combined volume of the solution is 49 mL, and the calculation shows that the moles of unreacted H+ ions is 0.001 mol. This leads to a concentration of H+ ions of 0.02 mol L-1. The resulting pH is calculated to be 1.69, confirming the accuracy of the solution. The response acknowledges the correctness of the calculation.
pavadrin
Calculate the pH after 24 mL of 1.00 M NaOH is added from the burette to a beaker containing 25.0 mL of 1.00 M HCl
pH = -log [H+]
1*10^-14 = [H+][OH-]
combined volume = 49mL
n.unreacted(H+) = 0.025-0.024 = 0.001 mol
[H+] = n/V = 0.001/0.049 = 0.02 mol L-1
pH = -log[H+] = 1.69 (2 d.p)
is that correct?
many thanks,
pavadrin
Yes.
okay thank you for the reply
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
