MHB Solution Set in interval notation for inequality
To solve the inequality 6x^2 - 2 > 9x, it is rewritten as 6x^2 - 9x - 2 = 0. The roots are calculated using the quadratic formula, yielding approximate values of -0.1964 and 1.6965. The quadratic expression represents an upward-opening parabola, indicating that the solution set excludes the interval between the roots due to the strict inequality. The final solution set in interval notation is expressed as (-∞, (9 - √129)/12) ∪ ((9 + √129)/12, ∞). This indicates the regions outside the roots where the inequality holds true.
datafiend
HI all,
I have the equation, 6x^2-2>9x for which I'm to find the solution set in interval notation.
I've rewritten the inequalty as 6X^2-9x-2=0. I tried to factor, but no go. Then I used the quadratic and got 9+/- rad(129)/-18. The answers I get for x are -1.1309 and .1309. The calculator gives. -.1964 and 1.6965. Is this just some rounding error?
Thanks,
Mathematics news on Phys.org
It should be $\dfrac{9\pm\sqrt{129}}{12}$. Your calculator is correct for approximate values.
You did well to move the $9x$ to the left so that you have:
$$6x^2-9x-2>0$$
Now, observing that expression is a quadratic, and that its graph will be parabolic, we see that it is an upward opening parabola since the coefficient of the squared term is positive. Thus, the expression must be negative in between the roots. Having the correct roots of the expression now, can you state the solution in interval notation?
I think -9+/-\sqrt{129}/-12 to negative infinity/positive infinity. Basically, the area between the pos and negative is excluded. Yes?
The region between and including the roots is excluded because we have a strict inequality. To express this using interval notation, we would write:
$$\left(-\infty,\frac{9-\sqrt{129}}{12}\right)\,\bigcup\,\left(\frac{9+\sqrt{129}}{12},\infty\right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
