MHB Solutions for arcsin(x) + arcsin(k) = π/2
  • Thread starter Thread starter SweatingBear
The equation arcsin(x) + arcsin(k) = π/2 is solvable for values of k in the range 0 ≤ k ≤ 1. The explicit solution for x can be expressed as x = √(1 - k²). The reasoning for the interval of k stems from the properties of the arcsin function, which requires both terms in the equation to be non-negative. A proof demonstrates that if either term were negative, it would lead to a contradiction, confirming that k must be non-negative. Thus, the correct interval for k is established as 0 ≤ k ≤ 1.
SweatingBear
Q: For which values of $$k$$ is the equation
$$\arcsin (x) + \arcsin (k) = \frac {\pi}2 \, ,$$
solvable? Furthermore, find an expression for explicit solution without arcus functions.
___________________________________________
S: Let us first find the explicit solution:
$$\arcsin (x) + \arcsin (k) = \frac {\pi}2 \ \Longleftrightarrow \ \arcsin (x) = \frac {\pi}2 - \arcsin (k) \, .$$
Since $$\arcsin (x)$$ is injective in its domain, $$x$$ must consequently equal the sine of $$\frac {\pi}2 - \arcsin (k)$$.
$$x = \sin \left[ \frac {\pi}2 - \arcsin (k) \right] \, .$$
The subtraction formulae yield
$$x = \underbrace{\sin \left( \frac {\pi}2 \right)}_{1}\cos \left[ \arcsin (k) \right] - \sin \left[ \arcsin (k) \right]\underbrace{\cos \left( \frac {\pi}2 \right)}_{0} \ \Longleftrightarrow \ x = \cos \left[ \arcsin (k) \right] \, .$$
We can derive $$\cos \left[\arcsin (k)\right] = \sqrt{1 - k^2}$$ by building right triangles and thus have
$$x = \sqrt{1 - k^2} \, .$$
In terms of finding an explicit solution for $$x$$ without arcus functions, it is correct. However we need to determine the interval of $$k$$. Looking at the argument of the square root one can conclude that, in order for $$x \in \mathbb{R}$$, we must have that $$-1 \leqslant k \leqslant 1$$. Surprisingly, it turns out that this interval is incorrect.
According to the key in my book, one must have that $$0 \leqslant k \leqslant 1$$ (and it makes sense, because if we plug in $$k = -1$$ in the given equation we arrive at an absurd relation). This is where I am stuck: I do not know where in my argument I can algebraically arrive at $$k \geqslant 0$$.
Here's a spontaneous thought: The domain of cosine is principally $$\left[0, \pi\right]$$ and therefore if $$x = \cos \left[ \arcsin (k) \right]$$ then $$0 \leqslant \arcsin (k) \leqslant \pi$$. But since $$\arcsin (k)$$ cannot be any greater than $$\frac{\pi}2$$, we must require that $$0 \leqslant \arcsin (k) \leqslant \frac{\pi}2$$. Consequently, since $$\arcsin (k)$$ is injective in that particular interval, we can finally arrive at $$0 \leqslant k \leqslant 1$$ (taking the sine of every side of inequality).
But I am still insecure about this particular method and train of thought. Anyone got a better suggestion?
Mathematics news on Phys.org
I would consider the identity:
$$\sin^{-1}(x)+\cos^{-1}(x)=\frac{\pi}{2}$$
Hence:
$$\sin^{-1}(k)=\cos^{-1}(x)$$
From this you will get the desired result...
@MarkFL: Ok, let us try that. For $$g(x) = \arccos (x)$$ we have that the range is $$0 \leq \arccos (x) \leq \pi$$. Since we are equating it to $$\arcsin (k)$$, one must require that
$$0 \leq \arcsin (k) \leq \pi \, .$$
This leads me back to the same line of argument as in my previous post. Since the inverse sine function cannot be any greater than $$\frac {\pi}2$$ we must require that
$$0 \leq \arcsin (k) \leq \frac {\pi}2 \, ,$$
and consequently have that $$0 \leq k \leq 1$$.
Does this mean that the argument I made in my previous post about the domain of the cosine function is valid?
sweatingbear said:
Here's a spontaneous thought: The domain of cosine is principally $$\left[0, \pi\right]$$ and therefore if $$x = \cos \left[ \arcsin (k) \right]$$ then $$0 \leq \arcsin (k) \leq \pi$$. But since $$\arcsin (k)$$ cannot be any greater than $$\frac{\pi}2$$, we must require that $$0 \leq \arcsin (k) \leq \frac{\pi}2$$. Consequently, since $$\arcsin (k)$$ is injective in that particular interval, we can finally arrive at $$0 \leq k \leq 1$$ (taking the sine of every side of inequality).
That line of reasoning looks absolutely correct. The range of the $\arcsin$ function is the interval $[-\pi/2,\pi/2]$. If two numbers in that interval have sum $\pi/2$ then they must both be non-negative. Therefore $$\arcsin (k)$$ must be non-negative, which means that $0\leqslant k\leqslant1$.
Great, thank you for the assessment.
My train of thoughts was on that track as well, however I did not find it to be sufficiently rigorous. As a matter of fact, I am struggling with wrapping my mind around that: Why do both terms necessarily have to be non-negative? Would it not be possible for the other number to be negative, the other one to be positive and their sum to still equal $$\frac {\pi}2$$.
On second thoughts, you are right; the both terms definitely need to be non-negative. Here is an idea for a proof.
Proof:
Suppose we have
$$p + q = \frac {\pi}2 \, ,$$
where
$$-\frac{\pi}2 \leqslant p, \, q \leqslant \frac{\pi}2 \ \ \wedge \ \ p, \, q \in \mathbb{R} \, . $$
Suppose either $$q$$ or $$p$$ is negative (does not matter which one, I choose $$q$$); then we can let $$q = -k$$ where $$k \in \mathbb{R}$$. Thus
$$p + (-k) = \frac {\pi}2 \ \Longleftrightarrow \ p = \frac {\pi}2 + k \, .$$
If it is the case that $$k > 0$$ then we have a contradiction because then $$p$$ would equal $$\frac {\pi}2$$ plus a small positive addition of $$k$$, which contradicts the requirement of $$p$$ maximally equalling $$\frac {\pi}2$$. The case $$k = 0$$ does not lead to a contradiction since $$p$$ is allowed to equal $$\frac {\pi}2$$. Thus $$p$$ and $$q$$ must be non-negative.
QED.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
