Solve 2^x=x^2+7 | Find x Without Differentiation
  • Thread starter Thread starter Harmony
The equation 2^x = x^2 + 7 has a solution at x = 5. Substituting values shows that x = 5 satisfies the equation, while other values do not. A graphical method is suggested for visualizing the solution, and the Newton method can be used for finding roots if substitution fails. The equation is recognized as transcendental, complicating direct analytical solutions. Overall, x = 5 is confirmed as the only solution without the need for differentiation.
Harmony
2^x=x^2+7
Find x.
The answer is 5. I have tried substituting 2^x=a, but that doesn't help. Is differentiation method required here? If not, how should I approach the question?
The equation is awfully transcendetal. My advice is to find the solution by a graphical method.
x=\frac{1}{\ln 2}\ln\left(x^{2}+7\right)
Daniel.
2^x = x^2 + 7
2^x - x^2 - 7 = 0
Now use the http://www.shodor.org/UNChem/math/Newton/index.html" to find root(s) of f(x) = 0
If the eqn, 2^x=x^2+7, looks simple enough you could try simple substitution.
x=1: 2 = 1 + 7 -- nope, lhs too small
x=2: 4 = 4 + 7 -- nope, lhs too small
x=3: 8 = 9 + 7 -- nope, lhs too small
x=4: 16 = 16 + 7 -- nope, lhs too small
x=5: 32 = 25 + 7 -- yep, lhs = rhs
If the above substitution method didn't work, and you went from lhs too small to rhs too large, with a value of x = xo, say, then you could try the http://www.shodor.org/UNChem/math/Newton/index.html" with xo as your first approximation.
