MHB Solve 2nd Order Linear Inhomogeneous ODE: Muhammad Fasih
The discussion focuses on solving the second-order linear inhomogeneous ordinary differential equation (ODE) y'' + 4y = xe^x + xsin(2x) using the method of undetermined coefficients. The annihilator method is employed to determine the appropriate form of the particular solution, leading to the conclusion that the operator (D-1)^2(D^2+4)^2 annihilates the right-hand side of the equation. The general solution combines both the homogeneous and particular solutions, resulting in a comprehensive expression for y(x). The final solution is presented as a combination of exponential and trigonometric functions, reflecting the contributions from both the homogeneous and particular components. The thread effectively illustrates the application of advanced techniques in solving complex differential equations.
MarkFL
MHB
Here is the question:
Solve the following differential equation y''+4y=xe^x+xsin2x by method of undetermined coefficients?
Please help me in doing this
I have no Idea of how to find the particular solution.
I have posted a link there to this thread so the OP may see my work.
Mathematics news on Phys.org
Hello Muhammad Fasih,
We are given the following ODE to solve:
$$y''+4y=xe^x+x\sin(2x)$$
Rather than referring to a table to determine the form of the particular solution, let's employ the annihilator method instead.
Let's look at the first term on the right side:
$$f(x)=xe^x$$
Differentiating, we find:
$$f'(x)=xe^x+e^x$$
$$f''(x)=xe^x+2e^x$$
Now, observing:
$$f''(x)-2f'(x)+f(x)=xe^x+2e^x-2\left(xe^x+e^x \right)+xe^x=0$$
We may conclude the differential operator:
$$A\equiv(D-1)^2$$
annihilates $f$.
Now, let's look at the second term on the right of the ODE.
$$g(x)=x\sin(2x)$$
$$g''(x)=4\left(\cos(2x)-x\sin(2x) \right)$$
$$g^{(4)}(x)=16\left(x\sin(2x)-2\cos(2x) \right)$$
Now, observing:
$$g^{(4)}(x)+8g''(x)+16g(x)=16\left(x\sin(2x)-2\cos(2x) \right)+32\left(\cos(2x)-x\sin(2x) \right)+16x\sin(2x)=0$$
$$A\equiv\left(D^2+4 \right)^2$$
annihilates $g$.
Hence, the operator:
$$C\equiv(D-1)^2\left(D^2+4 \right)^2$$
annhilates $f(x)+g(x)$.
Applying the operator to the ODE, we obtain:
$$\left((D-1)^2\left(D^2+4 \right)^3 \right)[y]=0$$
And for this homogeneous ODE with repeated characteristic roots, we obtain the general solution:
$$y(x)=\left(c_1+c_2x \right)e^x+\left(c_3+c_4x+c_5x^2 \right)\cos(2x)+\left(c_6+c_7x+c_8x^2 \right)\sin(2x)$$
Now, we know the solution to the original ODE will be the superposition of the homogenous and particular solutions. If we note that the homogenous solution is of the form:
$$y_h(x)=c_3\cos(2x)+c_6\sin(2x)$$
We may therefore conclude that the particular solution must have the form:
$$y_p(x)=\left(c_1+c_2x \right)e^x+\left(c_4x+c_5x^2 \right)\cos(2x)+\left(c_7x+c_8x^2 \right)\sin(2x)$$
Differentiating twice, and substituting into the original ODE, we obtain:
$$\left(5c_1+2c_2+5c_2x \right)e^x+\left(2c_5+4c_7+8c_8x \right)\cos(2x)+\left(-4c_4+2c_8-8c_5x \right)\sin(2x)=\left(0+1x \right)e^x+\left(0+0x \right)\cos(2x)+\left(0+1x \right)\sin(2x)$$
Equating coefficients, we obtain the system:
$$5c_1+2c_2=0$$
$$5c_2=1$$
$$2c_5+4c_7=0$$
$$8c_8=0$$
$$-4c_4+2c_8=0$$
$$-8c_5=1$$
From this, we obtain:
$$\left(c_1,c_2,c_4,c_5,c_7,c_8 \right)=\left(-\frac{2}{25},\frac{1}{5},0,-\frac{1}{8},\frac{1}{16},0 \right)$$
And so our particular solution is:
$$y_p(x)=\left(-\frac{2}{25}+\frac{1}{5}x \right)e^x+\left(-\frac{1}{8}x^2 \right)\cos(2x)+\left(\frac{1}{16}x \right)\sin(2x)$$
$$y_p(x)=\frac{5x-2}{25}e^x+\frac{x}{16}\left(\sin(2x)-2x\cos(2x) \right)$$
And so, the general solution to the given ODE is:
$$y(x)=y_h(x)+y_p(x)=c_1\cos(2x)+c_2\sin(2x)+\frac{5x-2}{25}e^x+\frac{x}{16}\left(\sin(2x)-2x\cos(2x) \right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
