Solve a Short Parabola Question with 2π/3 Period | Example Problem
  • Thread starter Thread starter tempeste
    Parabola Short
The discussion revolves around a problem involving a sine function with a period of 2π/3, but participants question its relevance to a parabola. The function is described as a constant value rather than a periodic function, leading to confusion about its characteristics such as amplitude and phase shift. There is a suggestion that the original question may contain an error, as it appears to ask for graphing a non-periodic straight line. One participant proposes a revised function that would better fit the context of the problem. The conversation highlights the need for clarity in mathematical problems involving trigonometric functions.
tempeste
http://img158.exs.cx/img158/5127/prob9cx.jpg
2pi/3 the period right?
3sin(2\pi /3)-4=-3.89...
It's not even a function (or a pretty boring one), it's a number And why do you associate a sine with a parabola?
I accidently made the assumption is was a parabola because the question asks for
amplitude, period, phase shift, domain, range, and vertical shift (but I know you can do this for a sine graph to)
Do you know how to graph it on a graphing calculator? I do not recall how to solve this type of problem =(
Well as I said it's a pretty boring function, it's a number. It's just a straight horizontal (if you plot y on the vertical axis) line throught the point y=3sin(2\pi /3)-4=-3.89.... I'm not sure it's meaningful to assign a period to it as it's not periodic.
there must be a mistake in the question, I am sure the book does not want us to graph a straight line over one full cycle?
I think it should be 3sin(x (not 0) - 2pi/3) -4
That would make much more sense
Thanks for your help will
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
