Solve by Method of Characteristics
  • Thread starter syj
  • Tags
    Method
In summary, the given problem involves solving a first-order linear PDE using the method of characteristics, with an initial condition that must be satisfied by the solution.
syj
55
[itex]u\frac{\delta u}{\delta x}[/itex]+[itex]\frac{\delta u}{\delta y}[/itex] =1
[itex]u|_{x=y}=\frac{x}{2}[/itex]
the characteristic equations to solve are:
[itex]\frac{dx}{ds}=u[/itex]
[itex]\frac{dy}{ds}=1[/itex]
[itex]\frac{du}{ds}=1[/itex]
I got the following equations from the characteristic equations:
[itex] \frac{dx}{ds}=u[/itex] means [itex]\frac{d^2x}{ds^2}=\frac{du}{ds}=1[/itex]
after integrating twice i get [itex]x=\frac{1}{2}s^2+ks+x_0[/itex]
[itex] y = s +y_{0} [/itex]
[itex] u = s +u_{0} [/itex]
and here is where I am now stuck.
I also don't know how to apply the condition given : [itex]u|_{x=y}=\frac{x}{2}[/itex]
Hello,
Thank you for your post. It seems that you are working on a partial differential equation (PDE) problem involving the variable u. In order to solve this problem, we first need to understand what the equation represents and what it is asking us to find.
From the given equation, it looks like we are dealing with a first-order linear PDE. This means that the highest derivative present is only first-order, and the equation is linear in u. This type of PDE can be solved using the method of characteristics, which is what you have started to do by finding the characteristic equations.
The characteristic equations are a set of differential equations that help us to find the solution to the PDE. They represent the curves along which the solution of the PDE is constant. In this case, we have three characteristic equations, one for each variable x, y, and u.
To solve the PDE, we need to find a solution that satisfies both the given equation and the initial condition u|_{x=y}=\frac{x}{2}. This initial condition tells us that at the points where x=y, the value of u is equal to half of x. This means that our solution must satisfy this condition at all points along the characteristic curves.
To find the solution, we can use the method of characteristics to find the general solution, and then use the initial condition to find the specific solution that satisfies both the PDE and the initial condition.
I hope this helps to clarify the problem and guide you in finding the solution. Keep up the good work in solving this PDE!
FAQ: Solve by Method of Characteristics
What is the "Method of Characteristics"?
The Method of Characteristics is a mathematical technique used to solve partial differential equations. It involves finding characteristic curves in the solution domain and using them to transform the partial differential equation into a system of ordinary differential equations, which can then be solved using standard techniques.
When is the Method of Characteristics used?
The Method of Characteristics is often used to solve linear partial differential equations with constant coefficients, such as the wave equation and heat equation. It can also be used for some nonlinear partial differential equations.
What are the steps involved in solving a problem using the Method of Characteristics?
The steps involved in solving a problem using the Method of Characteristics are as follows:
  1. Identify the partial differential equation and its boundary conditions.
  2. Find the characteristic curves by setting up a system of ordinary differential equations.
  3. Solve the system of ordinary differential equations to find the characteristic curves.
  4. Apply the boundary conditions to determine the constants of integration.
  5. Combine the characteristic curves and constants of integration to obtain the solution to the original partial differential equation.
What are the advantages of using the Method of Characteristics?
The Method of Characteristics has several advantages:
  • It can be used to solve a wide range of partial differential equations.
  • It provides an analytical solution, rather than a numerical one, which can be easier to interpret.
  • It can handle non-rectangular domains and irregular boundaries.
  • It is a systematic and well-defined method, making it easy to follow and reproduce.
Are there any limitations to the Method of Characteristics?
Yes, there are some limitations to the Method of Characteristics:
  • It can only be used for linear partial differential equations with constant coefficients.
  • It may not be suitable for problems with complex geometries or boundary conditions.
  • It can be computationally expensive for problems with high dimensions or large domains.
  • It may not be accurate for problems with strong nonlinearities or discontinuities.
