Solve Differential Eq.: dy/dx= 1/(xy+x^2y^3)
  • Thread starter Thread starter estalniath
    Method
estalniath
Hello guys,
Which method can we use to solve the differential equation below?
It doesn't seem to be of any form which I had studied before(linear differential equations,bernoulli,exact differential,homogeneous,seperable equations) for first order differential equations yet it appeared in one of out past examination questions :cry:
It's easy.For me
\frac{dy}{dx}=\frac{1}{xy+x^{2}y^{3}}
Therefore
\frac{dx}{dy}=yx+y^{3}x^{2}
Make the substitution
x=\frac{1}{u}
,under which
\frac{dx}{dy}=-\frac{1}{u^{2}}\frac{du}{dy}
Therefore the new ODE is
-\frac{1}{u^{2}}\frac{du}{dy}=\frac{y}{u}+y^{3}\frac{1}{u^{2}}
equivalently
\frac{du}{dy}=-yu-y^{3}
I trust you can take it from here.It's an nonhomegenous linear ODE...(the homogenous eq is separable).
Daniel.
Wow! That was a fast reply. =) Thank you for replying and how do you type the mathematical equations in between? I don't seem to see any functions in this thread which allows us to type mathematical functions?
Write formulas in latex code and use preview option for checking it b4 clicking submit.
Daniel.
I see. Thank you for the advice =)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
