Solve Diffraction Question: 2 Speakers 4.0m Apart, 325Hz, 343m/s, 4.5m Away
  • Thread starter Thread starter equanox
    Diffraction
The discussion revolves around solving a problem related to two-slit interference using sound waves from two speakers positioned 4.0 meters apart, emitting a frequency of 325 Hz. The key challenge is determining the spacing at which destructive interference occurs for students seated 4.5 meters away. Participants clarify that the condition for destructive interference involves the path length difference being a half-integer multiple of the wavelength. The equation v = f(λ) is relevant for calculating the wavelength, which is necessary to find the required spacing for destructive interference. Overall, the conversation emphasizes understanding the principles of wave interference to approach the problem effectively.
equanox
I am having difficulty with this problem because I am not quite sure where to start.
A lecturer is demonstrating two-slit interference with sound waves. Two speakers are used 4.0 meters apart. The sound frequency is 325 Hz and the speed of sound is 343 m/s. Students sit in seats 4.5 meters away. What is the spacing between the location where no sound is heard because of destructive interference?
x <center>lamda
_ = <center>____ ? (sorry these didn't line up too well)
L <center> d
I know full well that I'm supposed to show work, but the problem is that I don't know how to get started. I tried using the equation that I showed above, using 4.0 as d and 4.5 as L, but then that leaves frequency and speed of sound, which don't fit in. I then tried v=f(lamda), which works partially, except they aren't asking for wave length in this problem as far as I know. I can't figure out if there's too much information in the problem, or if I'm just looking at the wrong equations. Any help would be appreciated. Thanks.
Let's start from the top. What is the condition for destructive interference between two waves?
As an aside, this question has nothing to do with diffraction.
If separation is equal to 1/2 a wavelength plus a multiple of the wavelength there will be destructive interference, correct?
Correct, that is constructive interference occurs if the path length (L) of the two waves differ by,
L = \left(n+\frac{1}{2}\right)\lambda\;\;\;\;\; n\in\mathbb{Z}
Therefore, you need to find the shortest distance by which the two waves for the two speakers differ by a half-integer wavelength.
Okay...now I have a better idea of what I should do. If I have trouble I'll ask again. Thanks a lot for helping me :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
