Solve Doppler Effect Question 15: Find the Frequency Shift
The discussion revolves around solving a Doppler Effect problem related to frequency shift. The user has identified that the answer involves the sound moving 'away,' leading to options a or c. They calculated the frequency using the provided equation but found their result to be double the expected answer, suspecting an error in accounting for the medium's movement. It is suggested that the Doppler formula needs to be applied twice to account for the reflected signal from the moving blood. The complexity arises from treating the source velocity as effectively doubled due to the medium's motion.
accol
1. http://www.prep101.com/MCAT/102MCATPhysicsAnswers.pdf number 15
2. As you can see I already have the answers, I think I'm just doing something wrong.
3. I already know that the answer will be 'away' making it either a or c. So first I plugged the equation given (f1 = 1.0005f2) to get f2 and got approx 1569.2
So then I plug the values into this equation Fdelta/ fs = v/c
Just at the first part of the equation, (subtracting to get delta...I notice that I get .784, which is exactly double the correct answer. What am I missing here? There seems to be no multiplying by .5 or dividing by 2 anywhere in the question. I'm sure it's something small.
Thanks for the help
Someone correct me if i am wrong, but i suspect the issue is that the medium in which the sound is traveling is also moving. In other words, even though it is the blood that is the source, it is also the medium that the sound is moving in. The result would be that you would have to treat the problem by replacing the source velocity with 2 times the source velocity.
It's a bit tricky. You have to apply the Doppler formula twice.
The flow meter works by sending a signal that reflects off the blood. The received signal is the reflected signal.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
