Solve Entropy Change of Nitrogen in a Polytropic Process
  • Thread starter Thread starter mohdfasieh
    Interesting
The discussion revolves around calculating the entropy change of nitrogen gas during a polytropic process in a piston-cylinder device. The gas starts at 1.2 kg, 120 kPa, and 300 K, and is compressed to half its volume under the condition PV^1.3 = constant. Participants are encouraged to provide detailed solutions, as the original poster has struggled to find the necessary formulas in their textbook. The focus is on deriving the entropy change using appropriate thermodynamic principles. A clear solution is sought to resolve the confusion surrounding the calculations.
mohdfasieh
Hello all Genius people,
how r u .This question might be easy for u but i am not able to solve this question.Can anybody of u tell me to solve this problem in detail.I will be very thank ful to u .please please solve in detail.i have spent 2 days just thinking about this question but i was not able to get the right answer.
QUESTION :
A piston cylinder device contains 1.2 kg of nitrogen gas at 120 kpa and 300 kelvin. the gas is now compressed slowly in a polytropic process during whivh PV ^1.3=constant .The process end when the volume is reduced by one-half. Determine the entropy change of nitrogen during the process.
Surely your textbook contains a formula for caculating entropy under these conditions.
no sir nothing is giving for calculating entropy under such conditions please please tell me the solution of this question
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
