I Solve equation from dimensional analysis: 3 eq., 6 unknowns
Carlton's discussion focuses on the derivation of the thrust of a marine propeller based on various parameters, including diameter, speed of advance, rotational speed, fluid density, viscosity, and static pressure. The proportional relationship derived indicates that thrust (T) can be expressed in terms of these parameters with specific exponents for each variable. The confusion arises around solving for the constants c, f, and g, given three equations and six unknowns. The calculations suggest that setting c, f, and g to zero leads to a simplified solution, but this feels incorrect to the author. The lack of this solution in Carlton's text raises questions about its validity and the completeness of the derivation.
phillip_at_work
TL;DR Summary
Text book conducts dimensional analysis to derive an equation. Analysis involves 6 variables and 3 basic units (mass M, length L, and time T). This results in three equations and six unknowns. The final equation can be solved using three of those unknowns. However, with only three equations, I don't see how to find those three unknowns to actually get a solution for the derived equation. Text: Carlton 2007, Marine Propellers and Propulsion p89.
Carlton writes on page 89:
"The thrust of a marine propeller... may be expected to depend upon the following parameters:
(a) The diameter (D)
(b) the speed of advance (Va)
(c) The rotational speed (n)
(d) The density of the fluid (ρ)
(e) The viscosity of the fluid (μ)
(f) The static pressure of the fluid at the propeller station (p0-e)"
What follows is Carlton's derivation:
T ∝ ρaDbVacndμf(p0-e)g
And by dimensional analysis, we get:
MLT-2 = (ML-3)aLb(LT-1)c(T-1)d(ML-1T-1)f(ML-1T-2)g
which results in the following equations:
for mass M: 1 = a + f + g
for length L: 1 = -3a + b + c - f - g
for time T: -2 = -c - d - f - 2g
and hence:
a = 1 - f - g
b = 4 - c - 2f -g
d = 2 - c - f - 2g
And so that proportion can be updated to be:
T ∝ ρ (1-f-g) D (4-c-2f-g)Vacn(2-c-f-2g)μf(po-e)g
For the final equation as:
T = ρn2D4(Va/ nD)c* (μ / ρnD2)f* ( (p0-e) / pn2D2)g
I can follow this derivation without issue. What is confusing is how I solve for T. How can I know the values of `c`, `f`, and `g` as I have three equations and six unknowns? What am I missing?
I think I solved my own question. Happy for feedback.
Constant exponents are derived for ρa, nd and Db. These are ρ1, n2, and D4.
That is, a=1, d=2, and b=4. If I apply these to the system of three equations:
a = 1 = 1 - f - g
b = 4 = 4 - c - 2f -g
d = 2 = 2 - c - f - 2g
I compute,
g = f = c = 0
Which feels incorrect, but perhaps I'm over thinking. If this was correct, I'm not sure why Carlton wouldn't write this solution in the chapter, which s/he does not. Any feedback is much appreciated.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
