Solve for di: Negative Effect on Object Distance?
  • Thread starter Thread starter Grekory
    Lenses
To solve for the image distance (di) using the formula -di/do = hi/ho, first cross-multiply or multiply both sides by -do. Given the values ho = 3cm, hi = 4cm, and do = 5cm, the calculation leads to di = -6.67cm, indicating the image is inverted. The negative sign in the result signifies that the image formed is real and inverted. Understanding that negative di values correspond to real images clarifies the confusion around the negative aspect of the formula.
Grekory
When I'm given do, ho, and hi. How would i solve for di
Normally i would do -di/do = hi/ho and cross-multiply but I'm not sure how the negative comes into effect.
do = object distance
di = image distance
ho = object height
hi = image height
If...
ho = 3cm
hi = 4cm
do = 5cm
What would be di?
Thanks
Please provide the complete statement of the problem you are trying to solve. (I presume that a negative image height means that the image is inverted.)
It's just made up values and i want to know how i would solve for di. The negative in the formula confuses me
Start with:
-di/do = hi/ho
You can solve for di by cross-multiplying if you like, or just multiply both sides by -do. As I said before, a negative value for di just means that the image is inverted. (Real images are inverted.)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
