Solve for Focal Length of Convex Mirror: 1/50 + 1/20 = 1/-f
  • Thread starter Thread starter Aoiumi
    Mirrors Spherical
To find the focal length of a convex mirror, the equation 1/d0 + 1/di = 1/f is used, where d0 is the object distance (50 cm) and di is the image distance (-20 cm). The correct substitution leads to 1/50 + 1/-20 = 1/-f. The calculations reveal that f equals -33.3 cm, confirming the mirror's convex nature. The sign conventions for distances and focal lengths are crucial, with negative values indicating a convex mirror.
Aoiumi
An object is placed 50 cm in front of a convex mirror and its image is found to be 20 cm behind the mirror. What is the focal length of the mirror?
1/d0 + 1/di = 1/f
1/50 + 1/20 = 1/-f
70/1000 = 1/-f
f = 14.28 cm. The book has this answer listed at -33.3 cm. I'm not sure if the book is incorrect or if I did something incorrectly.
For the rest of this post I am going to assume the following conventions:
The mirror equation is
\frac{1}{d_o} + \frac{1}{d_i} = \frac{1}{f}
This equation applies to both convex and concave mirrors alike.
The convention is that the distances are positive if what they are measuring is in front of the mirror, and negative if behind the mirror. In other words, if the image is in front of the mirror then di is positive. If the image is behind the mirror then di is negative. The same goes for the object. (It goes without saying that the object will always be in front of the mirror. It doesn't even really make sense to put the object behind the mirror. It wouldn't have a reflection if it were placed behind the mirror. It just makes the convention easier to remember. Positive if in front of the mirror, negative if behind.)
Notice I haven't mentioned anything about the sign of focal length and how it relates to the equation. That's because I don't have to. Focal length signs work themselves out. There's another convention that says if the focal length is positive it's a concave mirror. If the focal length is negative it's convex. That same convention works with the above equation as-is.
1/d0 + 1/di = 1/f
1/50 + 1/20 = 1/-f
Two things. Firstly, the image is said to be behind the mirror. That means the di is -20 cm. Not positive.
1/50 + 1/20 = 1/-f
Secondly, don't put the negative sign in front of f. Just leave f as it is in the \frac{1}{d_o} + \frac{1}{d_i} = \frac{1}{f} equation. You don't need to change the equation.
If f turns out to be negative, meaning the mirror is convex, the math will tell you. You don't need to change the equation for this. As it turns out, the problem statement's assertion about the mirror being convex was superfluous information. It didn't need to tell you that to solve the problem. You could have figured that out just by doing the math.
Likes 1 person
Thank you so much for your clear explanation!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
